Thread: First Road Trip Questions
Results 1 to 10 of 10
  1. #1 First Road Trip Questions
    May 2013
    Grandville, MI
    I'll be taking my lady (girlfriend) and a couple friends on a road trip in my new (new for me) 2006 Grand Prix. It'll be the first road-trip I'll have taken in this car so I'm definitely pumped-up for the trip though I do have one concern.
    My front tires are much older than the rear. They're down to the line found on newer tires that indicate it's time to replace them. I just don't want to drop that much just before our trip for these tires. Anyways, we're going from Grand Rapids to the Detroit Zoo and back. I'm assuming I'll be fine but just want to get everyone else's opinions.
    I've babied this car so far and plan to going into the future. I'll be making sure the air pressure is perfect, it's perfectly clean, proper fluid levels, and make sure the oil is clear and at the correct level.
    Now I should also ask in regards to oil, do you recommend every 3-5,000 miles or do as some people like to and just change it once you can see the fluid itself turning a bit darker (no longer clear)?
  2. #2 Re: First Road Trip Questions
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Oil every 3,000. Tires should be okay, just be extra careful if it rains.
    Then when you get back, put them to rest with some proper burnouts.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  3. #3 Re: First Road Trip Questions
    Dec 2012
    Where 4T65E's were born
    Oil change intervals shouldn't go by color anymore because engines are burning cleaner, and can go 10k miles and still look pretty good.
    I'd suggest going 3-4k (max 5k) miles on conventional. If you do a lot of city, go closer to 3k. If you do a lot of highway driving, lean closer to 4k.
    With synthetic oil, I'd suggest 5-7k (max 10k) miles with the same rules as above(5-7k).
    Sold.
  4. #4 Re: First Road Trip Questions
    Grand Rapids, MI
    I've ran up past 8k miles on Mobil Synthetic and according to the oil test I did, it didn't lose any viscosity and could have went much further. Main thing is you HAVE oil in the motor for this trip lol
  5. #5 Re: First Road Trip Questions
    The Boss Iceman6669's Avatar
    Jun 2011
    i do 5-6k on my oil.. Never looks that bad
    2011 F-150 Yote powered
  6. #6 Re: First Road Trip Questions
    I would put the 2 good tires in the front and the 2 bad ones in the back.
    04 Comp G.
  7. #7 Re: First Road Trip Questions
    I usually go 5k or so on synthetic then change it and it still looks pretty clean then.
    04 Comp G.
  8. #8 Re: First Road Trip Questions
    Feb 2013
    37.295091, -121.930053
    unless your from Alaska then oil would be a problem
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  9. #9 Re: First Road Trip Questions
    Jun 2011
    PS. Detroit is not that far from GR. I made the trip 2 weeks ago. You should be fine.
  10. #10 Re: First Road Trip Questions
    I was going to say, I'm not googling it. How far are we talking. And I agree, plan on doing it when the weather is clear if you have tires w/o tread.
    And while I don't do it, the rule of tires is you put the better ones on the back. This way if you have to stop the rear won't lock and pass the front of the car.
  1. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  2. What to do about the really caked on road grime and road salt?
    By s1795so2 in forum Detailing Tips and Tricks
    Last Post: 12-09-2010, 06:55 PM
  3. 87 octane on long road trip.
    By gtpinsc in forum General Tech Discussion
    Last Post: 07-12-2010, 05:48 AM
  4. Road Trip!
    By Chernobyl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 02:07 PM
  5. road trip
    By pontiac88 in forum Off Topic Discussion
    Last Post: 01-14-2010, 09:36 PM
