On my 02 gt getting bad shaking at the listed speeds. We suspect bad cv axles. Question is should I do tierod? A few weeks ago did control arm and tie rod on passenger side as well as sway bar that was broke. Will be doing both cv axles and control arm on drivers side tomorrow. Had new front tires put on just after replacing passenger side parts a few weeks ago. Was hoping the tires were the problem but they were not. Also have new skf wheel bearings. Had an alignment done too. Am sure I will need another if I do driver side tierod. The tire place did not mention the tierod being bad though. But it is original. Just don't want to spend another 50 on an alignment if I dont have to
