Okay, hello everyone. So since the weather here has started to raise I have also noticed that so has my engine temperature. It runs slightly hot since the weather has changed. Also my air conditioner has started acting up. It will blow cold when the car is in park. However when the car is put in drive or reverse the compressor turns off and on like crazy and the air temperature from the vent turns warm. The system was reading a good charge although a little on the lower side of good. Does anyone have any ideas? Thank you in advance for all your help. It will also run funny if I have the radio on.
