Thread: Air Conditioner Compressor
Results 1 to 8 of 8
  1. #1 Air Conditioner Compressor
    Apr 2013
    Colonial Heights, VA
    Okay, hello everyone. So since the weather here has started to raise I have also noticed that so has my engine temperature. It runs slightly hot since the weather has changed. Also my air conditioner has started acting up. It will blow cold when the car is in park. However when the car is put in drive or reverse the compressor turns off and on like crazy and the air temperature from the vent turns warm. The system was reading a good charge although a little on the lower side of good. Does anyone have any ideas? Thank you in advance for all your help. It will also run funny if I have the radio on.
  2. #2 Re: Air Conditioner Compressor
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Your AC pressure is low thus the reason for the off and on action. It needs a recharge. Maybe a small leak.
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  3. #3 Re: Air Conditioner Compressor
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    ^^^yup, you probly notice it more in gear (driving) because as the rpm's increase,the suction pressure drops.Then the low pressure switch cuts off the compressor.Then the pressure goes back up and kicks the comp back on.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  4. #4 Re: Air Conditioner Compressor
    Apr 2013
    Okay. Than you guys. Is it really as easy as it says on the bottle to add freon? or would it be best to have it done by a professional? Also would the low pressure make my engine temp run a little high?
  5. #5 Re: Air Conditioner Compressor
    you can use those refill bottles from the parts stores. they work, yes its that easy screw it on the line push the button, fill till its in the green on the gauge on the can. done.
    but being your low now, it leaked out, so it wont last forever. maybe a week, maybe till next year. in the end, you want to find the leak and fix it, or your dumping 30 bucks a can into it all the time maybe.
  6. #6 Re: Air Conditioner Compressor
    Oct 2011
    MI
    PLEASE BE CAREFUL!
    Those cans are nice but they can increase the pressure to an unsafe level which can lead to compressor or line failure. The proper way is to have the car put on an a/c machine. It sucks the system dry and puts a vacuum on the system. Then it applies freon while the pressure stays at a safe level. Just a heads up.
  7. #7 Re: Air Conditioner Compressor
    redneck tennessee
    If your system is only a little low, just use the cans.If you get one with a little gaugeface on it, it will show you pressure,read the directions on the can and you wont overcharge it.You only need to vacume the system down if you got air in the system.Its not a big deal.Non-condensables (air) will only get in the system if it is out of freon, or very low with the compressor pulling a vacuume.
    (I am a nate certified commercial HVAC tech)
  8. #8 Re: Air Conditioner Compressor
    Oct 2011
    MI
    Putting a vacuum on the system with the machine removes all the freon from the system ensuring the proper ammount of freon goes into the system. So yes the proper way (and considering the machine is automated) is for it to be pulled down and refilled to spec.
    I agree the cans are fine if you use the ones with a gauge.
  1. leather seat conditioner
    By vandezand in forum Visual/Body Modifications
    Last Post: 03-30-2013, 09:02 PM
  2. 2001 Grand prix air conditioner blower goes to slow speed.
    By ddecker70 in forum General Tech Discussion
    Last Post: 09-02-2012, 07:13 AM
  3. 05 GP Air Conditioner Not blowing cold anymore
    By mpoynter31 in forum General Tech Discussion
    Last Post: 05-19-2012, 06:53 PM
  4. Air Conditioner Not Turning On
    By mjacob in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2011, 11:33 PM
  5. air conditioner compressor
    By justwhisen in forum Shops and Community Heroes
    Last Post: 09-03-2008, 07:29 AM
