Thread: EVAP purge/vent solenoid?
Results 1 to 11 of 11
  1. #1 EVAP purge/vent solenoid?
    Jul 2012
    Texas
    Engine light has been on for a while and finally got it checked out at Autozone. It came back with this...
    EVAP purge/vent solenoid circuit condition
    1. Purge or vent solenoids defective
    2. Check connector and wiring
    3. Fuel saturated vapor canister
    4. Failed EVAP vent solenoid
    Can anyone point me in the right direction on how to fix this? Is this something that would be an easy fix or should I just take it somewhere and let them do it?
  2. #2 Re: EVAP purge/vent solenoid?
    SE Level Member Bragill25's Avatar
    Sep 2012
    Michigan
    I've got the same code. I'm going to my mechanic tomorrow and i'll see what he says and if it works.
  3. #3 Re: EVAP purge/vent solenoid?
    GT Level Member GP Guy 07's Avatar
    Feb 2013
    Elgin
    Its not to hard to fix and replace.I had to replace both purge and vent solinoids on my car.The purge solinoid is on the upper intake manifold on the backside towards the brake resorvior,with one I want to say 10mm bolt.But make sure you know which one for sure to fix. The vent solinoid canister is connected to the filler tube for gas on the rear drivers side and its not hard to replace yourself,maybe a 30 min job.
    07 GP black on black,SPO spoiler,grills,hai,aftermarket rims,Led tails,drilled+slotted rotors
  4. #4 Re: EVAP purge/vent solenoid?
    Jul 2012
    Texas
    Quote Originally Posted by GP Guy 07 View Post
    This is a big help, thanks. Where did you get your parts from?
  5. #5 Re: EVAP purge/vent solenoid?
    Feb 2013
    Elgin
    Advance Auto because I didn't want to wait,or you could go with Rock Auto to save money.It depends on if you're able to fill your car when getting gas,what I mean is I was having trouble filling up at the pump because it wouldn't start right up.Hope that helps.
  6. #6 Re: EVAP purge/vent solenoid?
    Jul 2012
    Texas
    Went ahead and changed out the purge solenoid tonight. Did your engine light turn off by itself or did you unhook the battery for a while?
  7. #7 Re: EVAP purge/vent solenoid?
    Feb 2013
    Elgin
    I took the battery cable off for about 30 mins and no light.
  8. #8 Re: EVAP purge/vent solenoid?
    Jul 2012
    Texas
    Would either of those solenoids cause my car to have trouble starting?
  9. #9 Re: EVAP purge/vent solenoid?
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    I need to change one of the 2 also.
  10. #10 Re: EVAP purge/vent solenoid?
    Feb 2013
    Elgin
    Quote Originally Posted by OriginalName View Post
    Not that I know of? Mine fired right up.
  11. #11 Re: EVAP purge/vent solenoid?
    Apr 2013
    michigan
    While replacing my solenoid today there was dirt in the line and solenoid. Is that a good sign that the other end of the hose is undone and thats when i was getting the 455 code?
  1. DTC P1655 EVAP Purge Solenoid Control Circuit
    By fju2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-30-2011, 11:34 AM
  2. will a purge solenoid make your car run like crap
    By dstrow73 in forum General Tech Discussion
    Last Post: 04-02-2011, 07:28 AM
  3. Purge Vent Valve/Solenoid testing
    By roundbox52 in forum General Tech Discussion
    Last Post: 09-29-2010, 07:36 PM
