Thread: PDF manual needed for removing the dash
Results 1 to 3 of 3
  1. #1 PDF manual needed for removing the dash
    Mar 2013
    Chatham Ontario
    Hi, can anybody help me by providing the instructions/ preferably a PDF downloadable file manual for removing the entire dash assembly for a 2002 Grand Prix GT- I need to replace my dash, I spoke with my mechanic who told me this is a 10 hour ordeal- so it will cost a bit...If this can be done by a non mechanic- like me- is it possible??? I was told that there are many, many wires- connections as well the entire steering column has to be dropped down and removed?????? My passenger side air bag cover was damaged, air bag is NOT blown, so far I have 3 options...1- buy a used complete dash and remove/ replace 2- buy a used airbag unit which apparently comes with the cover- this I don't understand as it doesn't look like the cover is really a part of the air bag anyways??? It seems to be attached to the dash??? 3- buy a used/ aftermarket air bag cover from the U.S on ebay and simply OR NOT SO SIMPLY take apart my current dash which is in very good shape- mint actually...and replace the damaged cover with the new one- however I have NOOOOO idea what I'm doing, what to pull/ pry/ unscrew/ unplug- any help/ advice is much appreciated. I seen an earlier post on here from another member who was mentioning he had a PDF manual for removing the dash assembly- please reply anyone
    Thanx
  2. #2 Re: PDF manual needed for removing the dash
    Waukesha, WI
    theres a complete manual PDF download over at GPONA.org/com whatever it is.
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #3 Re: PDF manual needed for removing the dash
    Banned
    Sioux Falls, SD
    If the pad on the pass side is just damaged and nothing else is on the dash just replace the pad itself. Call a junk yard and ask, alot easier than replacing your whole dash
  1. Needed- WHOLE- dash assembly for a 2002 grand prix gt
    By mclifford in forum Introductions/Noob Questions
    Last Post: 03-20-2013, 09:04 PM
  2. Photoshop removing door contact bars needed
    By cleaningman94 in forum Off Topic Discussion
    Last Post: 09-24-2012, 12:10 AM
  3. removing/replacing dash?
    By JESSEGOTTA GP GT in forum Visual/Body Modifications
    Last Post: 05-29-2011, 08:02 PM
  4. removing dash 97 gp se
    By 97gp97 in forum General Tech Discussion
    Last Post: 03-23-2009, 03:00 PM
