Thread: Fuel Doors getting lazy on me. Help?
Results 1 to 12 of 12
  1. #1 Fuel Doors getting lazy on me. Help?
    Mar 2013
    Canton, Ohio
    My fuel door is sagging. I have no idea how to fix it. Anyone know how? Maybe a video or pics? It's been like this for a while now. I believe the top hinge or whatever holds it is broke.
    thanks!
  2. #2 Re: Fuel Doors getting lazy on me. Help?
    I believe they have rivets holding it in place.
    I am un-sure if anyone has pictures on the fix of it.
  3. #3 Re: Fuel Doors getting lazy on me. Help?
    GT Level Member GrandPriest24's Avatar
    Jan 2013
    Michigan
    You have to pull out inner fender and go underneath there are 3 screws you have to tighten them up I had that problem before
  4. #4 Re: Fuel Doors getting lazy on me. Help?
    Mar 2013
    Canton, Ohio
    Alright Ill give it a shot if I ever get some decent weather over here.
  5. #5 Re: Fuel Doors getting lazy on me. Help?
    Feb 2013
    37.295091, -121.930053
    Welcome!!
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  6. #6 Re: Fuel Doors getting lazy on me. Help?
    Donating Users 1quikgp's Avatar
    Jan 2009
    Ohio
    I actually had to replace the pin that holds the hinge together, it had rusted, and broke in half. Might want to check that if all your screws are tight.
  7. #7 Re: Fuel Doors getting lazy on me. Help?
    Mar 2013
    Canton, Ohio
    How so? Cause just from the fuel door and the wheel well i see 1 screw. Cant see where the hinge is, its like right around the corner of the of the fuel door.
  8. #8 Re: Fuel Doors getting lazy on me. Help?
    Jan 2009
    Ohio
    When you open the fuel door there are 4 screws and two rivets. Remove screws, drill out rivets, and the whole fuel door assembly can be removed.
  9. #9 Re: Fuel Doors getting lazy on me. Help?
    Mar 2013
    Canton, Ohio
    Gotcha on the 4 screws. I'm a little confused on "rivets?"
  10. #10 Re: Fuel Doors getting lazy on me. Help?
    Jan 2009
    Ohio
    When you open the door, there are two rivets on the left hand side above and below the hinge. Should be silver...the other two things left after you take out the screws. Those are the rivets and need to be drilled out to remove.
  11. #11 Re: Fuel Doors getting lazy on me. Help?
    Mar 2013
    Canton, Ohio
    Gotcha. I thought that's what they were but I wasn't sure. Then it pulls out through the wheel well?
  12. #12 Re: Fuel Doors getting lazy on me. Help?
    Jan 2009
    Ohio
    It will just pull out. No need to remove the tire or open the trunk. It just pulls straight out. You'll see when you drill the rivets out.
  1. To Lazy
    By Hidenface in forum Introductions/Noob Questions
    Last Post: 11-02-2012, 07:04 PM
  2. finally got off my lazy as's
    By gtcoup in forum Off Topic Discussion
    Last Post: 08-21-2011, 08:52 PM
  3. Rap Real Lazy
    By LowRidinCrew in forum Off Topic Discussion
    Last Post: 06-01-2011, 03:19 PM
  4. Lazy Boost
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2011, 08:35 PM
  5. Greetings from The Lazy R !!!
    By thelazyr in forum Introductions/Noob Questions
    Last Post: 08-27-2010, 06:21 PM
