Thread: ignition stuck on
Results 1 to 11 of 11
  1. #1 ignition stuck on
    SE Level Member 97GPJJ's Avatar
    Dec 2012
    grand rapids
    im having problems with my key coming out it. the car turns off but it doesnt turn back far enough to take key out.
    im not sure if its the ignition cylinder or the solenoid
    any ideas?
    97 grand prix - sold
    2000 grand prix gtp xp cam,3.2 pulley ,tog headers
  2. #2 Re: ignition stuck on
    Under the steering wheel thingy is a small tab you can pop out, stick a screw driver or whatever up there and you'll push up a white tab, that will release the key. You can take the cover off and super duper glue that white tab up and you'll never have the issue again.................maybe, lol.
  3. #3 Re: ignition stuck on
    Donating Users mystic231's Avatar
    Michigan
    My '98 had this issue. It was a broken wire on a switch in the console that actuates when the shifter is put into park.
    It could also be a bad solenoid in the column, but I would check the wire harness in the console first.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  4. #4 Re: ignition stuck on
    Dec 2012
    grand rapids
    i read that it could be the igntion switch cause mine is bad im pretty sure cause
    dic turns off when heat is on
    heat pnly works on high ( has brand new blower resistor)
    headlights flash off when heat is turned on
  5. #5 Re: ignition stuck on
    Mar 2013
    s/Wisconsin
    just fixed mine today. took the solenoid out, put the small metal plunger in my vice and twisted the mother off , re installed it , problem solved.
    could have just left it out , but didn't.
  6. #6 Re: ignition stuck on
    Donating Users
    Jan 2014
    West Virginia
    So what is the cause of the issue here, mine is starting to do this crap now........
    Fixedwing1
    2000 GTP 3.8 S/C
    Kenwood / Infinity Audio: 17" Konigs w/ 245/50/17 Gmax tires: Headlight retrofit W/ Morimoto minis: Flipped dog bones
  7. #7 Re: ignition stuck on
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  8. #8 Re: ignition stuck on
    The Boss Iceman6669's Avatar
    Jun 2011
    Take cover off the under side of steering wheel... Rip this dam thing out
    Never have an issue again.
    2011 F-150 Yote powered
  9. #9 Re: ignition stuck on
    Nov 2009
    A little late
    yep, thats it. ^^^^
    may need a E4? external torx, but it will come out without one with some force
  10. #10 Re: ignition stuck on
    Donating Users
    Jan 2014
    West Virginia
    Gee, thanks Madness hadn't thought of that!! Seriously I appreciate your other links, I did try and search and hasn't come across but one of those. Obviously didnt use the right combo of keywords. Gives me a few things to look into, I will investigate the broken wire issues first and so forth, kinda guy who wants things to work as made, but guess if I can't diagnose and fix properly, I have other things to fall back on now. Thanks again.
    Fixedwing1
    2000 GTP 3.8 S/C
  11. #11 Re: ignition stuck on
    you can pop the pin out of the plug, the broken wire pin that is. and then get a new wire from a junk yard and splice it in.
    or cut and splice it back together if theres enough wire left to work with off the plug.
    solder and shrink tubes works best. it never fails.
  1. Key gets stuck in the ignition
    By mikethevike384 in forum Introductions/Noob Questions
    Last Post: 04-15-2012, 11:33 AM
  2. Key Stuck in Ignition and Shifter Stuck in Park
    By GRAFIX in forum General Tech Discussion
    Last Post: 02-25-2012, 02:50 PM
  3. Key stuck in the ignition
    By Gearhead Garland in forum General Tech Discussion
    Last Post: 01-31-2012, 06:32 PM
  4. Key stuck in ignition.
    By at2smithjason in forum General Tech Discussion
    Last Post: 03-31-2010, 06:16 PM
  5. key stuck in ignition....
    By fst in forum General Tech Discussion
    Last Post: 01-21-2010, 06:06 PM
