Thread: oil puddle on top of intake
Results 1 to 17 of 17
  1. #1 oil puddle on top of intake
    SE Level Member 97GPJJ's Avatar
    Dec 2012
    grand rapids
    driving around in my car and stopped cause i smelled something funny. when i came to a stop my car started smoking and i pop the hood and looked and theres a big puddle of oil and maybe anti freeze
    I have just done both upper and lower (plenum) gaskets 2 days prior and cleaned everything . i talked to a friend of mine and he told me i probaby need a new motor
    i cant afford a new motor someone please help
    97 grand prix - sold
    2000 grand prix gtp xp cam,3.2 pulley ,tog headers
  2. #2 Re: oil puddle on top of intake
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    I hope you did an oil change right after you did the gaskets.
  3. #3 Re: oil puddle on top of intake
    Dec 2012
    grand rapids
    yes i did with walmart oil
    im going to change it again soon
  4. #4 Re: oil puddle on top of intake
    you use thread sealant on the lim bolts? if not that could be where the leaks are from.
    any pics of said puddles?
  5. #5 Re: oil puddle on top of intake
    Dec 2012
    grand rapids
    yes used selant
    idk how to upload pics on here
    otherwise i would
  6. #6 Re: oil puddle on top of intake
    GT Level Member Dakoda's Avatar
    Feb 2013
    Illinois
    and the puddle was on top of your intake plenum?
  7. #7 Re: oil puddle on top of intake
    Dec 2010
    DMV
    Photobucket. Copy IMG links
  8. #8 Re: oil puddle on top of intake
  9. #9 Re: oil puddle on top of intake
    Dec 2012
    grand rapids
  10. #10 Re: oil puddle on top of intake
    take a paper towel, fold it up into a square, then wipe under the valve coves lip. it could leaking v/c gaskets.
    if they are dry, clean the puddle up, then spray it all down with brake cleaner, then watch it closely to see where its coming from over the next day or so.
    when you mop the puddle up try to see if its a mix or just oil, its hard to tell in the pics what it is.
    and is it just that one bolt valley with a puddle?
  11. #11 Re: oil puddle on top of intake
    Dec 2012
    grand rapids
    yes it just that bolt valley
  12. #12 Re: oil puddle on top of intake
    Feb 2013
    Illinois
    idk if its just the picture but it does look to be a little greenish... hopefully not but do what scotty said and go from there
  13. #13 Re: oil puddle on top of intake
    you know what it does look greenish, and there looks to be a green dot on the edge of the t stat housing, maybe thats your leak?
  14. #14 Re: oil puddle on top of intake
    Dec 2012
    grand rapids
    it is a little greenish
  15. #15 Re: oil puddle on top of intake
    Feb 2013
    Illinois
    did you replace the thermostat gasket when you did the gaskets?
  16. #16 Re: oil puddle on top of intake
    Dec 2012
    grand rapids
    Quote Originally Posted by Dakoda View Post
    negative
  17. #17 Re: oil puddle on top of intake
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    What does the paper towel smell like after you clean it up? Antifreeze would be obvious.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  1. Water Puddle On Driver's Front Foot Area
    By Dabman in forum General Tech Discussion
    Last Post: 01-29-2013, 09:46 PM
  2. Replies: 2
    Last Post: 03-31-2012, 07:49 PM
  3. antifreeze puddle on top on motor?
    By blazed16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2012, 03:50 PM
