Thread: Oil Pressure Sensor Location
Results 1 to 2 of 2
  1. #1 Oil Pressure Sensor Location
    Mar 2013
    Safford Arizona
    I'm trying to find out where the oil pressure sensor is located. If it's bad will I be losing oil?
  2. #2 Re: Oil Pressure Sensor Location
    it leaks bad when it goes bad, starts out small gets real bad fast.
    take your pass side wheel off look at the oil filter, just past it is a sensor with a plug, if its leaking the plug will be wet with oil.
    to change it, reach in, un plug it, then put a small pail under it cause oils gonna leak out when you remove it. use channel lock pliers reach in un screw it, same for the install, but stop when its snug, just into the thread sealant on the new sensor or you WILL split the housing.
  1. Sensor location...
    By boosted98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2013, 01:45 PM
  2. O2 Sensor Location Help
    By 97GTzbban1 in forum General Tech Discussion
    Last Post: 03-20-2011, 08:30 PM
  3. sensor location
    By fritzie001 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2011, 11:41 PM
  4. ECT sensor location?
    By il0vellamas in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-29-2010, 02:27 PM
  5. A/C low pressure line location on 98 GTP
    By Juanmiguel in forum General Tech Discussion
    Last Post: 02-26-2010, 10:02 PM
