i just got my 03 grand prix gt se and i dont know how to fix the traction can someone give me some tips
say please
wheel speed sensor fix and done
yes the abs light is on
ABS and traction control will always be off untill you fix whatever is causing the ABS light to be on.
You will have to get the car scanned with a reader that can do ABS codes. Its either a wheel bearing(s), wiring problem or the abs module itself.
i don't know what this traction control, you speak of, is?
9 times out of ten its a wheel speed sensor
Hey buddy! i litterally had this same issue a week ago on my 2000 GT. all mine turned out to be was the pig tail clip on the back of the wheel hub. you have a little clip connecting 2 wires that lead into your wheel hub; all mine was, was one was cut. all it took was a 16$ clip and 2 butt connectors and about 30 mins. mine was on the front left tire, nice and easy. Hope this helps! there are a million different things it could be! try fuse 13 under the hood as well. and jack your car up and spin each wheel and see if it grinds, if it grinds then it might be a wheel hub
