Wow so glad I found this forum !! So about my wifes car, Mamas Rocket. 1997 GTP, rare 2door. Just getting the last of a few issues worked out. where I am at . I have the ever present abs lowtire lights on. Replaced the rotors with ne brakes, and cleand the terminals. I can trick" the abs off by restarting the car while I rolling in neutral. .. More issues.. I can hear a groan from the right front hub as I load and unload weight to it by swearving back and forth at 30mph. Jacked it up and found grease spray on back of the tire but the boot was NOT torn. Also It seems to be alot of play in the transmission side of the axle. so the questions
1. Is the play in the axle normal?
2. If the hub assy was bad, would it cause the abs light issue to?
Thanks
Dwight
Mamas Rocket Monkey Wrencher
