Thread: Fuel injector and/or Starter Probs
Results 1 to 3 of 3
  1. #1 Fuel injector and/or Starter Probs
    Jan 2013
    Brookings, SD
    I think I have to give you a sort of story to make you fully understand my question. So here goes:
    So I go out to my car and start it. She starts normally. I go in the store so I shut it off for a half hour or so. I go back, and she starts noticeably rougher. I go to another store and go to start her again about a half hour later. She turns over, then immediately dies after reaching idle. So I try again and the same happens: she dies immediately after reaching idle. So I try again, this time working the gas, giving it enough fuel to keep the rpms above idle. After revving for a couple seconds, I let off the gas and she dies immediately. I try a fourth time, working the gas and easing off the pedal slowly. This time, she is able to stay alive but I can smell something burning. I've had this issue every time I try to start her any more than 2 times per hour. I'm thinking its a bad starter, but at the same time I think it could be the Fuel Injector or the gas lines. Any help would be much appreciated! Thanks!
  2. #2 Re: Fuel injector and/or Starter Probs
    Clean the MAF sensor, the IAC valve and the entire throttle body. After that see what its like.
    Its not a starter problem, most of the time the throttle body is super dirty along with those sensors and can cause these problems.
  3. #3 Re: Fuel injector and/or Starter Probs
    Jan 2013
    Wausau, wi
    Check the fuel pressure it could be the pump? See if it bleeds back. There is a hole in trunk too get at the pump if you need too replace it.
  1. Fuel injector help !!!!
    By GTPAIELLO in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2012, 06:48 AM
  2. fuel injector resistance
    By Viprklr in forum 5.3L V8 (LS4)
    Last Post: 06-17-2012, 11:48 AM
  3. Fuel Injector O-Rings
    By bobabooie in forum General Tech Discussion
    Last Post: 04-07-2011, 07:08 AM
  4. Fuel injector seating
    By chrisgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 10:42 AM
  5. Which fuel injector?? is there a difference?
    By Bigbm80 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2010, 09:55 PM
