how exactly do you install the guages like a volt meter and fuel/air ratio one and a boost that will lead to a vaccum hose? i want to see if theres any way i could do this by myself or have a professional do it
The air/fuel ratio gauge aka little light show that is useless hooks to your O2 sensor in the engine. You can purchase a pig tail that will essentially make it plug and play from ZZP.
The volt meter is an electrical hook up that tells you the volts of the car typically hooked to your alt. The vac source for the boost gauge can be T'd into the vaccum line coming off the LIM.
You should be able to do a search to come up with detailed directions on here. Or look at the directions that come with the gauges they are fairly straightforward.
Thanks! really helped out! thinking i can do it by myself
