Thread: dome lamp issues timer circut inop no dome lamp or floor lights
Results 1 to 3 of 3
  1. #1 dome lamp issues timer circut inop no dome lamp or floor lights
    SE Level Member rgroffel's Avatar
    Dec 2012
    Quinton ,virginia
    dome light inop any info on it checked fuses relays dimmer switch door switches ect but still no lights ? all data just gives me the standard grand prix not the gtp vin code 1 version with sc ? i dont want to go to dealer but it may be my last choice
  2. #2 Re: dome lamp issues timer circut inop no dome lamp or floor lights
    GTP Level Member 1ATony's Avatar
    mass
    Welcome to the site
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  3. #3 Re: dome lamp issues timer circut inop no dome lamp or floor lights
    Dec 2012
    Quinton ,virginia
    ok since i was the only one here let any one know in the future look for the obvious first found after market mobile phone / aka on star hooked up to fuse panel jumped in instead of directly tieing into voltage drop pin rain water flowed over the intake hole for the hvac port causeing the water to pool up in floor basin the mobile phone shorted out the input side of he fuse panel hardwire going to the firewall power box burning up the fuse port no power to the relay for dome lamp and since the relay is ground fired lol cant energise the relay
  1. Dome/Map lights
    By JCG's-GTP in forum 04+ Specifics
    Last Post: 02-22-2012, 09:11 AM
  2. Dome light issues, help
    By cojo in forum General Tech Discussion
    Last Post: 04-13-2011, 06:21 AM
  3. Dome Lamp Disable Mode
    By Scanner in forum General Tech Discussion
    Last Post: 10-12-2010, 09:32 AM
  4. Dome Lights
    By betsgtp in forum Audio, Security & Visual Electronics
    Last Post: 09-30-2010, 03:29 PM
  5. How do you remove the backseat dome lamp housings?
    By salannelson in forum Audio, Security & Visual Electronics
    Last Post: 07-10-2010, 12:10 AM
