Thread: *Pics* Resale or replace? Moisture in headlight.
Results 1 to 7 of 7
  1. #1 *Pics* Resale or replace? Moisture in headlight.
    GT Level Member Jtiger360's Avatar
    Nov 2012
    United States
    Reseal or replace? I was restoring my headlights, because they where cloudy and the driver side came out perfect looks new, however when I was restoring the passenger side I notices half of the so called "haze" is moisture inside the headlight. Should I go to a JY and replace it or stick it in the oven and reseal it? What are the steps to resealing it?
  2. #2 Re: *Pics* Resale or replace? Moisture in headlight.
    Nov 2012
    United States
    Reseal not resale sorry
    I live here. DirtDog's Avatar
    Jun 2012
    Just take and drill a really small hole on the bottom somewhere where it can't be seen. That'll fix ur problem easy way
    Sent from my pager using Morse code. ... .. ... ....
  4. #4 Re: *Pics* Resale or replace? Moisture in headlight.
    Nov 2012
    United States
    Quote Originally Posted by marines542 View Post
    Nice! Thanks I am going to try that!
    Jun 2012
    Drill it somewhere hidden though
    Or you could do it the right way and put them in the oven for about 10 mins at 200 or so. (Note: make have to leave them in there longer or up the temp..generally this is what I do). Use a old flathead and crack them open. Use the same flathead and scrap out as much of the old silicon as you can then you butyl also known as window weld and put a bead of that around the headlight. Without the lense use either a heathen or stove to soften it up then slap the lense back on and use plastic clamps to squeeze them together and leave them over nite. Wipe off any excess butyl or silicon you get on the lenses before it dries.
    04 Comp G.
    Jun 2012
    I've never tried that before but I do know that's the way to take them apart. And I know for a fact it would work
  1. How to Replace 96 Grand Prix HEadlight Assembly?! HELP!!
    By buckshotnc82 in forum Visual/Body Modifications
    Last Post: 05-28-2011, 03:55 AM
  2. New headlight output HORRIBLE need help (pics)!
    By Frank217 in forum Visual/Body Modifications
    Last Post: 08-08-2010, 05:58 PM
  3. Brightest bulbs for headlight replace?
    By krafty81 in forum Audio, Security & Visual Electronics
    Last Post: 08-05-2010, 09:34 AM
  4. Headlight Question w/ PICS
    Last Post: 06-10-2010, 05:17 PM
  5. Moisture in Headlights
    By Dohner in forum Visual/Body Modifications
    Last Post: 02-19-2008, 01:39 AM
