Thread: Gas gauge issue?
Results 1 to 6 of 6
  1. #1 Gas gauge issue?
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    So when I start my car on a cold start, the gas gauge shows under E and all the lights pop up after a few seconds of idling. Once I start driving, the gauge goes to the correct level. When I'm going up a hill, the gauge will fly up to nearly close to full, probably three quarters full, when I'm going up probably a 30 degree incline and the tank is really less than a quarter full. What could my issue be?
  2. #2 Re: Gas gauge issue?
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    Sending unit time.
    Its a common "GM thing" Trail blazers/Envoys, Safari/Astro vans, Montana and its sister van Full size pickups, S-series, all have the same basic type of Sending unit and pump assy.
    There is a replacement part you can get at the parts store for under $30. Installs on your pump assembly in the tank. Removal of the pump assy from the tank is required.
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  3. #3 Re: Gas gauge issue?
    Sep 2012
    Clarkston, MI
    Excellent, thank you for the information Jay!
  4. #4 Re: Gas gauge issue?
    Youtube "bonnieville fuel level sender replacement"
    Watch the 3 part video.
  5. #5 Re: Gas gauge issue?
    Sep 2012
    Clarkston, MI
  6. #6 Re: Gas gauge issue?
    Ontario, Canada
    No prob, I'm here to help when/where I can.
    Jay
  1. 1996 GTP - Temp Gauge / Fan Issue
    By tcbtec1 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 05-11-2012, 07:54 AM
  2. Fuel Gauge Issue
    By Lawenforcer in forum General Tech Discussion
    Last Post: 02-25-2012, 01:47 PM
  3. Help With Temperature Gauge issue!
    By gcschi22 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-02-2011, 10:55 AM
  4. Rpm Gauge issue
    By PTGsDaytona500GTP in forum General Tech Discussion
    Last Post: 09-27-2011, 10:20 AM
  5. boost gauge issue vid
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2009, 09:44 PM
