Thread: newbie with a question
Results 1 to 20 of 35
  1. #1 newbie with a question
    Oct 2012
    Milwaukee, WI
    I have a 97 gtp and a 02 gp and i want to swap engines can I do it and what all would I need to change?
    Thanks
  2. #2 Re: newbie with a question
    antioch ill
    what motors are in them if you are swapping a 3.1 with a 3.8 you need to swap teh cradles too and teh pcms
  3. #3 Re: newbie with a question
    Not worth the trouble.
    And if you search, all this information is on this website.
  4. #4 Re: newbie with a question
    Oct 2012
    Milwaukee, WI
    both are 3.8
  5. #5 Re: newbie with a question
    Jan 2012
    Philadelphia
    You will need a 98-02 GTP PCM
    The 97 GTP PCM is different
    Why would you want to swap engines?
  6. #6 Re: newbie with a question
    Oct 2012
    Milwaukee, WI
    would it be better to buy a turbo for my 02 then
  7. #7 Re: newbie with a question
    Jan 2012
    Philadelphia
    If you have the money but with a turbo you will destroy the stock transmission
  8. #8 Re: newbie with a question
    Oct 2012
    Milwaukee, WI
    my 02 is a 40th anniversary in better shape
  9. #9 Re: newbie with a question
    Jan 2012
    Philadelphia
    You could top swap it that would be easier IMO rather then going though the hassle of swapping engines
  10. #10 Re: newbie with a question
    Jan 2012
    Philadelphia
    http://www.grandprixforums.net/top-s...info-7763.html
    http://www.grandprixforums.net/safel...0-a-67580.html
    If you plan on a top swap read these first..
    They should get you started and get an idea of what to do
  11. #11 Re: newbie with a question
    Oct 2012
    Milwaukee, WI
    ya i could do that the only reason i want to swap engines cuz i would also swap the trannys my 97gtp tranny has a shift kit
  12. #12 Re: newbie with a question
    Idk I think it depends on how mechanically inclined he is and if he has someone close to him to help him tune the car.
  13. #13 Re: newbie with a question
    The 97 trans wont work in the 02, the valve body is different and the cooler lines are different as well. The cooler lines are easy to fix but the valve body idk.
  14. #14 Re: newbie with a question
    Jan 2012
    Philadelphia
    Shift kits are cheap and easy, trust me its not worth your time to swap the transmissions because of the shift kit
  15. #15 Re: newbie with a question
    You have a few days of reading ahead of you.
    You need to understand that a GT and GTP arent so much alike.
    Sure the motors and trans carry the same name, but each are alot different.
    GT is 9.4:1 compression and GTP is 8.5:1, GT trans has 3.29 gears, GTP has 2.93's. Both have the same strength, both will die with enough power.
    97 GTP PCM is year only and MUST have the wire harness to use it in another car.
    You'd be better off top swapping the GT, instead of swapping motor. Whatever you decide on will need a full on custom tune to make anything work.
  16. #16 Re: newbie with a question
    Oct 2012
    Milwaukee, WI
    Dam i thought this would be easier
  17. #17 Re: newbie with a question
    Thats what sucks about having a 97 car, everything is different, trans, pcm, blower, abs, hub bearings, DIC. Its the bastard child of the Grand Prix world. Why everyone says if your looking for a GP go 98-02 because 03's have a some one off parts as well.
  18. #18 Re: newbie with a question
    Jan 2012
    Philadelphia
    I love my 97 GTP
  19. #19 Re: newbie with a question
    Oct 2012
    Milwaukee, WI
    so does everyone think that i should just do a top swap.
  20. #20 Re: newbie with a question
    Jan 2012
    Philadelphia
    I think you should
  1. Newbie Question.....
    By generalqwer in forum General Grand Prix Discussion
    Last Post: 05-28-2012, 03:49 PM
  2. interior lights/exterior lights newbie question
    By spider4 in forum General Tech Discussion
    Last Post: 11-10-2011, 08:34 PM
  3. Newbie radio question
    By nickfinity in forum Audio, Security & Visual Electronics
    Last Post: 02-15-2011, 10:14 AM
  4. Hello. newbie with question!
    By Jbrigs in forum Introductions/Noob Questions
    Last Post: 09-22-2009, 05:20 PM
  5. Newbie with a question
    By BHMJohn in forum Introductions/Noob Questions
    Last Post: 08-24-2008, 08:24 PM
