Thread: Engine and Transmission swap from an 04 to a 99 GP
Results 1 to 10 of 10
  1. #1 Engine and Transmission swap from an 04 to a 99 GP
    Jul 2012
    Mandan North Dakota
    I have a 99 gtp with a broken tranny, and the engine has 220,000miles on it so i want to change them both, i found an engine and Transmission out of an 04 CompG GTP and was wondering if that engine and transmission will just bolt into my car. or if i will have to do any PCM or instrument panel modifications to make it work?
  2. #2 Re: Engine and Transmission swap from an 04 to a 99 GP
    Short answer, no.
    It will not work.
    Engine and trans are different than your cars, even if you used the PCM from the 04 car, it will not match up to anything else in the 99 car.
    You need a 97-02 trans from a supercharged car.
  3. #3 Re: Engine and Transmission swap from an 04 to a 99 GP
    The only thing that is materially different or that wouldn't work well in your car is the transmission. You can easily use the engine with a throttle body adapter and fuel rail swap. (you have your old fuel rail)
  4. #4 Re: Engine and Transmission swap from an 04 to a 99 GP
    Jul 2012
    Mandan North Dakota
    where can i get the throttle body adapter?
  5. #5 Re: Engine and Transmission swap from an 04 to a 99 GP
    Either 98IraqVet, maybe ebay or ZZP
  6. #6 Re: Engine and Transmission swap from an 04 to a 99 GP
    I take it he didnt read much of our posts with a reply like that.
    Sure you can use the motor no problem, but its not just a drop in and drive type of deal, there are many small things that have to be changed in order to run it correctly.
    And as said before, you can't use the transmission.
  7. #7 Re: Engine and Transmission swap from an 04 to a 99 GP
    Doesn't mean he didn't read my post and decide to go forward on teh motor.
  8. #8 Re: Engine and Transmission swap from an 04 to a 99 GP
    Jul 2012
    Mandan North Dakota
    so would you suggest dropping that motor in or not? what all needs to be changed? i planned on doing a cam, and intercool, injectors, im sure ill have to have wiring harnesses changed also.?
  9. #9 Re: Engine and Transmission swap from an 04 to a 99 GP
    Here's what you do. Put your map sensor, TB (with adapter), evap or use the Gen V evap, run a pcv port to the TB (drill and tap) and it'll go right in.
  10. #10 Re: Engine and Transmission swap from an 04 to a 99 GP
    GTP Level Member 1ATony's Avatar
    mass
    Welcome to the site
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  1. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  2. Transmission swap.
    By Tuner-Extraordinaire in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-13-2011, 01:54 PM
  3. Transmission Swap
    By cmal37 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-30-2011, 08:42 PM
  4. transmission swap
    By jrock in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-13-2011, 01:04 AM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
