Thread: Help is it head gasket water pump or intake gasket
Results 1 to 7 of 7
  1. #1 Help is it head gasket water pump or intake gasket
    taylorville illinois
    I have a 97 gp gt with a 3.8 that doesnt over heat but uses a lot of anti freeze i cant find a leak but the car runs cold until its real low on anti freeze would appreciate any help
  2. #2 Re: Help is it head gasket water pump or intake gasket
    Omaha, NE
  3. #3 Re: Help is it head gasket water pump or intake gasket
    Welcome, it's your lower intake manifold gasket. Head gaskets rarely go bad on these cars.
  4. #4 Re: Help is it head gasket water pump or intake gasket
    GT Level Member lrscgod's Avatar
    Shellman Bluff, GA
    I have 4 cars with the 3.8 and every one has the aluminum gaskets now. Piss poor original design by GM.
  5. #5 Re: Help is it head gasket water pump or intake gasket
    How much should this cost me to get fixed?
  6. #6 Re: Help is it head gasket water pump or intake gasket
    if you do it yourself under $100. If you take it somewhere probably around $500-$600
  7. #7 Re: Help is it head gasket water pump or intake gasket
    Welcome...
    It's not typically going to be a lower intake manifold using that much coolant. It's most likely your upper intake manifold has sprung a leak in teh coolant port right next to the EGR tube area. The easy way to tell is to pull your throttle body off, it's 3 10mm nuts. Then you'll be able to see the hole and EGR tube. If they are wet, you will know for sure. While you are doing that, it is always recommended to replace the LIM' gaskets with aluminum ones as they will look like hell.
  1. cracked head blown head gasket or just done??
    By roytoy70 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2012, 10:40 PM
  2. Head Gasket
    By develand in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-16-2011, 06:39 AM
  3. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
  4. Intake or Head Gasket?
    By trailshredder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-22-2010, 03:11 PM
  5. bad head gasket?
    By nscottp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-08-2009, 08:51 AM
