Hello, first post. Have 2008 PG GXP. Remote start won't work. Decice is activated, lights flash when button on fob iss pushed, but engine won't start.
if there is a pending cel or a cel currently it will not start. also the key fobs are prone to breaking. take the fob apart and put a small wad of aluminum foil on the contact pad. put it together and try again.
i dont get it..... cel ??? also if the lights flash, wouldnt that mean that the button on the fob is making contact????
( i have the same problem with remote start, never thought it was really an issue, but when i get back to my car it will be winter)
cel is check engine light. i missed the lights flashing part. yes the fob is working. if you do not have a check engine light then i dont know what else it could be.
question is the key fob look like a factory one or aftermarket? if it's aftermarket you need to check into it a little more.
