Having a misfire problem only when supercharger kicks in. All tune up done. One coil is sparking red instead of blue already changed it and the new one does same thing its the number one coil.
Plug or wire problem. Swap with another to see what it is. Each coil fires 2 plugs at the same time so if the other plug on same coil is good, the coil is probable good.
