Thread: Air Conditioning fan cuts out at 3500 RPM
Results 1 to 7 of 7
  1. #1 Air Conditioning fan cuts out at 3500 RPM
    Jun 2011
    Pennsylvania
    Has anyone else experienced this. Just got the car.
    Test 1
    Turn on Air Conditioning
    Turn on Re-circulation
    Rev engine to 3500 RPM + (enter expressway quickly)
    Air Conditioning shuts down
    Re-circulation light stays on
    reduce speed, engine less than 3k - 3.5k
    Air conditioning ramps back up, Re-circulation stays on.
    Test 2
    Turn on Air conditioning
    Turn off Re-circulation
    Air Conditioning shuts down???
    Re-circulation stays off - no light
    Re-circulation turns on, light turns on and you can hear AC ramp up.
    Air conditioning is back up, Re-circulation stays on.
  2. #2 Re: Air Conditioning fan cuts out at 3500 RPM
    May 2008
    Winnipeg, MB
    solution don't rev so high, its actually a safety feature to protect fan, been around for at least two decades
    my last car, a 1991 Olds Eighty-Eight would do the same thing, found out the hard way once when I was speeding and it got very warm in the car until I slowed down
    2007 Pontiac Grand Prix
  3. #3 Re: Air Conditioning fan cuts out at 3500 RPM
    SE Level Member 1fastgtp's Avatar
    Jun 2011
    Lewiston
    welcome
    2000 Grand Prix GTP: Modifications: SLP catback exhaust-SLP Headers- 180 Termostat- wizaired cold air intake-PRJ 10.4mm wires- autolite 104's- zzp tune- full size intercooler- vs cam- 3.0" pulley ETC. Fastest Grocery Gitter in town
  4. #4 Re: Air Conditioning fan cuts out at 3500 RPM
    HUDSON
    There is a check valve that keeps the vacuum in the vacuum resivour when pressure on the engine side rises (heavy throttle), or there might be a vacuum leak on the resivour side of the system.
  5. #5 Re: Air Conditioning fan cuts out at 3500 RPM
    Feb 2010
    Virginia
    yup AC supposed to cut off at WOT isnt it?
  6. #6 Re: Air Conditioning fan cuts out at 3500 RPM
    Delaware, OH
    Quote Originally Posted by Justintiime View Post
    Yep. Actually happens all the time for me with the stall. Get's rather annoying.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  7. #7 Re: Air Conditioning fan cuts out at 3500 RPM
    FWIW that can be reprogrammed.
    It's done that way to give you max power. Clearly if you are over 70% throttle, you are asking for everything it's got.
  1. Engine cuts out
    By DLAVENGER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-25-2010, 10:07 PM
