Thread: 3800 s/c knocking noise or piston slap
Results 1 to 6 of 6
  1. #1 3800 s/c knocking noise or piston slap
    rochelle,il
    i rebuilt my 3800 s/c because somehow i put a valve rod thru a piston and it landed under the s/c in the intake manifold hmmmm.... but anyways its back up and running bored 30 over could this noise be piston slap? noise is only at higher rpm. could the 30 over cause a lose in boost because the added space and would a smaller pulley fix it? also has new trans and torque converter
  2. #2 Re: 3800 s/c knocking noise or piston slap
    GTX Level Member Biohazed's Avatar
    Philadelphia, Pennsylvania, United States
    Wrong section, this really should be posted in the L67/L32 section....
    Anyway a few questions, was the block Line honed when you had it machined? what size Pulley are you running atm, what other engine mods are you running, is your PCM tuned or stock? what condition are the rotors in the SC in? what other work was done to the engine and SC?
    the more info you can give us the better people can help you
    *image too tall*
    BMR F + R Strut Bars - Falken Torque V 18's - JVC S900 - Kicker C10's - Spyder Projectors, Wizaird,
  3. #3 Re: 3800 s/c knocking noise or piston slap
    Jul 2008
    sumter,south carolina
    video... or if u cant do that... take the SC belt off and see if noise goes away.
    02 GTP with mods 05 GP for DD
  4. #4 Re: 3800 s/c knocking noise or piston slap
    rochelle,il
    yes it was line honed and pistons are over sized. s/c is fine take the belt off and the noise is still thereits in the back cylinders. i am running the stock pulley i could probably drop a size to et the boost back but im trying to figure out the noise all clearances were good everything is brand new.sry about the wrong section new to this site
  5. #5 Re: 3800 s/c knocking noise or piston slap
    if the bore is 30 over... are the pistons 30 over as well? and what was the ring gap set to?
  6. #6 Re: 3800 s/c knocking noise or piston slap
    Nov 2009
    Grand haven
    new lifters? new rods? rockers loose? stock rockers? weak spring since it is only at a higher rpm? MORE INFO.
  1. Busted piston!!!!
    By lambokit in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2013, 11:10 AM
  2. Knocking Noise While Braking
    By jonrk7 in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2010, 02:14 PM
  3. clutch piston?
    By murp9302 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2010, 10:53 PM
  4. Could this be a hole in #1 piston?
    By guys00gtp in forum Off Topic Discussion
    Last Post: 06-24-2010, 03:27 PM
  5. knocking noise. HELP
    By GMtuner29 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2010, 07:39 PM
