Thread: Engine Cranks but Will not Start
Results 1 to 4 of 4
  1. #1 Engine Cranks but Will not Start
    Donating Users
    Knoxville, TN
    Just recently got a 1998 Grand Prix SE from a family member. It was given to me as it quit running on them and they did not want to spend the time or money to repair!!! They gave it to me as they know I like to tinker with autos and other equipment
    Ran across this site and saw some very interesting posts! I thought this would
    be a great place to look for information. Have recently worked on the car and
    found the following:
    > Engine is a 3.8 naturally aspirated
    > Engine would crank but would not start
    > Could not hear fuel pump starting
    > Checked for fuel pressure on the fuel rail and had none
    > Had good spark from coil and from wires
    > Changed plugs
    > Replaced fuel pump
    > Removed injectors; cleaned and replaced "O-Rings"
    > Can hear fuel pump now and have fuel pressure at fuel rail
    > Engine turns over but still will not start
    Now I am wondering if I have a bad crank sensor or something or possibly
    a timing problem!!!!!
    Good to be a part of this forum and look forward to chatting some.
  2. #2 Re: Engine Cranks but Will not Start
    MO
    If you suspect the crank position, do a search for CPS here, that is a common problem. Welcome
    <brandonl2000> LMAO D!!
  3. #3 Re: Engine Cranks but Will not Start
    n/a
    Could be a CKP problem as well. Look at the scan tool while cranking to make sure you have a CMP signal as well as a CMP signal. You find that by looking at the RPM pid and the CMP Yes/No. Should be "Yes" obviously.
  4. #4 Re: Engine Cranks but Will not Start
    Bonaire 31005
    welcome
  1. car cranks but wont start unless you press accelerator
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 10:49 PM
  2. cranks wont start
    By zach_gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2009, 08:10 PM
  3. Cranks over but will not start
    By wfj8251 in forum General Tech Discussion
    Last Post: 02-08-2009, 02:47 PM
  4. HELP! Cranks then Don't Crank
    By Bigboy49251 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2009, 03:25 PM
  5. engine will start only if
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2008, 07:34 PM
