Thread: Cylinder Misfire!
Results 1 to 20 of 26
  1. #1 Cylinder Misfire!
    SE Level Member AFBCamaro's Avatar
    Florida
    Hello, Im new here. I have a cylinder 3 misfire is that enough mods to to put a 3.2 pulley?
    Thank you for your advise.
  2. #2 Re: Cylinder Misfire!
    What?!?
  3. #3 Re: Cylinder Misfire!
    Quote Originally Posted by AFBCamaro View Post
    With a misfire you should be good to go to a 2.8 pulley. Nitrous would probably help out alot.
  4. #4 Re: Cylinder Misfire!
    Florida
    Haha, you really didnt describe you situation at all AFB.
    Dont do a pulley drop until there are NO misfires.
    I can imagine lots of boost, not properly tuned with a misfire would **** a piston up.
    If you can please post all your current mods, we can tell you what pulley to go with when the misfire is GONE
  5. #5 Re: Cylinder Misfire!
    Probably straight pipe with a cold air. its fassssssssst
  6. #6 Re: Cylinder Misfire!
    Jul 2008
    Tampa, FL
    i like this new guy already...haha
  7. #7 Re: Cylinder Misfire!
    Florida
    I just ordered a clogged cat for my down pipe. 2.8 MPS pulley here i come!!
    Thank you to all the advice given. Great community!!
  8. #8 Re: Cylinder Misfire!
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  9. #9 Re: Cylinder Misfire!
    Florida
    Oh god, He didnt order a clogged cat, he ordered my catless ZZP DP, and AFB, DONT drop any pulley sizes until you're engine is safe to do so.
    READ THIS. http://www.grandprixforums.net/f81/s...car-17482.html
    A 2.8 pulley requires massive amounts of mods, including an intercooler.
    Please dont blow your **** up.
  10. #10 Re: Cylinder Misfire!
    Florida
    A AHAHAHAHAH AHAHAHHA guys i was just joking. Im new to the grand prix but not blown motors. Thank you though for caring, seriously!
    List of mods--
    Cylinder 3 misfire
    Clogged cat
    2.6 Pulley
    Inter-cooler Heater blanket
    22lb Injectors
    TB restriction plate
    TR2 Spark Plugs
    Homemade Slicks with traction steel belts sticking out thread
    Overdrive pulleys
    Stacked paper filters
    Leaking Valve Covers
    Fuel Set at stoich 14.7 at full throttle
    Oh and sagging back springs with reinforced rust.
    1/4 19.7 at 55mph
  11. #11 Re: Cylinder Misfire!
    Florida
    Im trying to build up my post count so that I can sell a aftermarket cd/mp3 aux radio that I have in the gtp. :-)
  12. #12 Re: Cylinder Misfire!
    Newnan, GA
    I bet if you throw in a steering wheel control unit and you will have some people interested in it. That is the kicker for most, they don't wan to lose the steering wheel controls.
  13. #13 Re: Cylinder Misfire!
    Newnan, GA
    List of mods--
    Cylinder 3 misfire
    Clogged cat
    2.6 Pulley
    22lb Injectors
    TR2 Spark Plugs
    Overdrive pulleys
    1/4 19.7 at 55mph
    All of that and you didn't even get custom warped pistons?
  14. #14 Re: Cylinder Misfire!
    List of mods--
    Cylinder 3 misfire
    Clogged cat
    2.6 Pulley
    22lb Injectors
    TR2 Spark Plugs
    Overdrive pulleys
    1/4 19.7 at 55mph
    If that rust wasn't reinforced I bet you could easily run a 19.3. That extra weight is killing you. The weight savings from the rust are being offset by the reinforcing.
  15. #15 Re: Cylinder Misfire!
    Florida
    I just ordered some cast cracked pistons! They have been weight shaved for lightness and speed yo! (ricer)
    I just sprayed rust converter on my rust and will be taking off the reinforcements. 19.2 here i come!
    *-Stock GTP-- For now!
    *-1991 Camaro RS. 355 Forged Bottom end. CNCed 230CC heads. 6-71 GMC Detroit Roots Blower. 1 7/8 Headman Ceramic Headers. Twin 600CFM Holleys carburetors. 3.42 Rear Posi. Runs on AV Gas 100LL.
  16. #16 Re: Cylinder Misfire!
    Newnan, GA
    ^When u put them don't forget to remove the rings. Everyone knows that burning oil produces more power than gas.
  17. #17 Re: Cylinder Misfire!
    Florida
    Piston ring removal, man that's old school. I go a step higher I remove the piston bores before install. You think the motor was lubricated before.
  18. #18 Re: Cylinder Misfire!
    Florida
    Cha ching, I just scored a set of honda fouled spark plugs and broken timing chain to replace mine.
  19. #19 Re: Cylinder Misfire!
    Troy OH
    this is a pretty awesome thread haha
  20. #20 Re: Cylinder Misfire!
    Newnan, GA
    Have u put in a ZZP GT pcm yet? That thing will really bring ur car to life! The more aggressive the better, right?
  1. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  2. Cylinder 3 Misfire
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2010, 11:24 PM
  3. Cylinder 3 misfire...please help!!!
    By swifty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2010, 07:21 PM
  4. Cylinder #4 misfire
    By Kompton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 08:41 AM
  5. #4 cylinder misfire
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 06:16 PM
