Thread: New member and first time Pontiac Grand Prix owner (first pontiac ever)
Results 1 to 6 of 6
  1. #1 New member and first time Pontiac Grand Prix owner (first pontiac ever)
    Nov 2009
    York, PA
    Howdy from south central PA. Formerly a Mopar fanatic... I recently strayed from my normal habits and put my money into a 1997 Pontiac Grand Prix GT (non-supercharged K-vin series). Test drive had me hooked. Now mind you... I am used to driving a Dodge Stealth (5spd manual naturally aspirated) and could not fathom that there was a better car than this, the test drive in the Grand Prix proved me wrong even though it is only an automatic. I loved every aspect of it. I knew the fuel pump was bad because my fuel indicator was reporting full tank although it was only 1/4 full and so forth. What has snuck up on me now is the dreaded intake manifold leak. Well I suspect that's what it is after some research and work on the car. A few days after the purchase I noticed the temps rising and falling drastically (usual suspect for faulty thermostat/water pump) and proceeded to change out the thermostat and topped it off while I was at it. No change in rapid rising and falling of coolant temps. I am going to change the water pump and flush the system while I am at it because I did noticed additives in the radiator cap fill area. What is leading me to believe that I have a leak in the intake area is because #6 is misfiring and the RPMs are all over the place and the coolant smoke is up near the top of the engine rather than down by the water pump. I have yet to pull #6 to see the condition of the spark plug. I just hope I can just pull the top end off and replace the gaskets all the way around. I probably should even in the event that it is not the problem to save myself the headache later.
    Anyrate... Pontiac has won a convert despite my current setbacks. I look forward to learning more from the well rounded veterans here in future modifications I have in mind for this car.
  2. #2 Re: New member and first time Pontiac Grand Prix owner (first pontiac ever)
    Donating Users busmech's Avatar
    Apr 2009
    Minneapolis MN
    Welcome to the forums...One quick bit of advice...i got a 98 GTP and had a similar problem...turns out it was air in the system...there is a bleeder screw on top the t'stat housing at least on my gtp there is...open that with engine idling until pure coolant comes out...might help...
    "Turbocharging is nice...but I'd rather be BLOWN!!!
  3. #3 Re: New member and first time Pontiac Grand Prix owner (first pontiac ever)
    Donating Users r33na's Avatar
    wi
    welcome and goodluck with your current issues..
    2k8 PONTiAC GRAND PRiX
  4. #4 Re: New member and first time Pontiac Grand Prix owner (first pontiac ever)
    Nov 2009
    York, PA
    buemech... thanks for the tip... i will try that when I am able to get home from work when it's not dark. :-)
  5. #5 Re: New member and first time Pontiac Grand Prix owner (first pontiac ever)
    SE Level Member Toxicologist's Avatar
    Albany, California
    Welcome and congrats on the purchase. These cars are great.
  6. #6 Re: New member and first time Pontiac Grand Prix owner (first pontiac ever)
    Nov 2009
    Grand haven
    Welcome!!
  1. 2004 Pontiac Grand Prix
    By davma1 in forum General Tech Discussion
    Last Post: 08-31-2009, 08:36 AM
  2. Pontiac Grand Prix SE '97
    By Grandprixse97 in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-07-2009, 10:52 AM
  3. New member and Grand Prix Owner!
    By 99GPGT in forum Introductions/Noob Questions
    Last Post: 06-10-2008, 11:15 PM
  4. 2000 Pontiac Grand Prix GT
    By 2000grandprixGT in forum Introductions/Noob Questions
    Last Post: 03-18-2008, 08:23 PM
