Thread: Houston here, 2002 GT
Results 1 to 4 of 4
  1. #1 Houston here, 2002 GT
    Houston, TX
    Hello everyone, I am new to this forum but have been on a few others before...I found this forum while I was looking for help to fix my GT as she has been out of commission for awhile now. I finally have determined the problems, and after searching the forums for an answer, I might be posting my question.
    If anyone sees this, can a bad knock sensor cause the a/c to not blow cold? Don't mean to sound stupid, but the timeframe of my a/c not blowind cold matches when I believed my knock sensor went bad...
  2. #2 Re: Houston here, 2002 GT
    SE Level Member singularity's Avatar
    Houston, Tx
    Hi, welcome to the forums, im pretty new on this forum, and to my car. (98 GTP) Im from houston as well, down near stafford
    We are both cursed with A/C problems i guess, Mine will not blow to just one area, it blows through the defroster, the face, and the feet, no matter what selection i make on the DCC
  3. #3 Re: Houston here, 2002 GT
    Donating Users mystic231's Avatar
    Michigan
    No. Knock sensor retards engine timing. Nothing to do with the A/C system.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  4. #4 Re: Houston here, 2002 GT
    Houston, TX
    Yeah I figured as much Mystic, but for some reason at the same time my knock sensor problem popped up my a/c stopped blowing cold, but I also have an electrical issue so it might be due to that, who knows?
    Also, I have been trying to figure out a gas leak for awhile now, and think I almost got it. I have a 2002 GT and on the top of the engine near the back of the intake manifold there is a plastic fuel supply line with a 90 degree connector that connects to a plastic quick connect fitting that hooks to a metal fuel (I guess fueal rail) line. - have replaced the 3/8 quick connects many times but have finally figured out that its the o-rings inside that 90 degree fitting.
    Does anyone know what I am talking about, how to fix it, and if I can buy those o-rings or the piece? I will post photos to help...
    MODS-if I need to put this in a different thread or something please let me know..
  1. Houston region
    By Ninjo in forum Southwest
    Last Post: 09-15-2009, 10:05 PM
  2. Hello from Houston.
    By singularity in forum Introductions/Noob Questions
    Last Post: 08-19-2009, 09:02 AM
  3. hello from houston got an 05
    By salez775 in forum Introductions/Noob Questions
    Last Post: 04-09-2009, 02:11 PM
  4. Houston we have a PROBLEM!!
    By fratzke7 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-14-2008, 12:45 PM
  5. New Grand Prix Owner Houston TX
    By mainecrab in forum Introductions/Noob Questions
    Last Post: 02-17-2008, 08:56 AM
