Her 99 gtp has no fuel pressure. I have checked all fueses done the 85 relay bypass and connot hear the pump running.Is there an access hole in the trunk? Iwant to check for voltage at the pump.Whatis the best pump to buy.Our budget is tight.
yh....pull up the carpet in the trunk and close to the rear seat there will be an access panel with a few bolts holding it down. easy to get too
Last time I checked Amazon had the cheapest price for my '02. It was on a OEM Delphi pump, around $246.
