Thread: FIPK install question
Results 1 to 6 of 6
  1. #1 FIPK install question
    Omaha NE
    I have a 02 GTP and have purchased a FIPK for it and can't get it to fit. I spoke to someone at K&N and they told me this should also fit this Supercharged car. It does not fit in the space in front of the wheel. Does anybody out ther have a GTP with this kit on it? Part number is 57-3045 this in the one K&N said would fit.
    Thanks
  2. #2 Re: FIPK install question
    Donating Users mystic231's Avatar
    Michigan
    Welcome! This would be seen by more eyes if it was in the correct forum, especially since I don't think a lot of people have FIPK's.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  3. #3 Re: FIPK install question
    Houston, TX for now
    First of all welcome. I have a FIPK on a 2000 GTP. I don't know the part number, but it does fit great. If I remeber it was a tricky getting it in right the first time.
    2000 GRAND PRIX GTP COUPE WITH THE NORMAL LIST MODS TO MAKE IT LOUDER, FASTER AND OF COURSE SEXIER!! 267 WHP @ 9000 FT ABOVE SEA LEVEL
  4. #4 Re: FIPK install question
    Ohio
    Welcome. i had one on my 2000 gtp for awhile it was a bit tricky to slip in but it fits perfectly if u follow ur directions
    00 GTP demodded and forsale
  5. #5 Re: FIPK install question
    GT Level Member BoostedComp's Avatar
    Youngstown
    welcome! sorry to hear your having issues with the intake good luck!
  6. #6 Re: FIPK install question
    Donating Users chico's Avatar
    I guess your not ready for a cam install yet J.K. I have the K&N kit and it fits great you obviously are doing something wrong ,first off put this question in the proper forum then try posting pics of what your issue is I do'nt see how it would'nt fit unless you have the wrong part number?
    04 gto stock,97 GPGT l-36 block diamond pistons ,l-32 rods ,custom comp cam grind,HS 1-7 RR, p&p heads, SS IC,SS M-90 3.5" ,4t60eHD,from Gonzales TX.
  1. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  2. Homemade FWI Install Question
    By High Rolling GTP in forum General Tech Discussion
    Last Post: 02-01-2009, 08:51 AM
  3. Total lift after rocker install.Question
    By TDCRacing in forum General Tech Discussion
    Last Post: 12-06-2008, 04:03 PM
  4. 3" Downpipe install question
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2008, 07:21 AM
  5. Cam Install Kit- What do I really need?
    By 1998gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 01:40 PM
