Thread: New to group - leaking factory sunroof
Results 1 to 9 of 9
  1. #1 New to group - leaking factory sunroof
    Nov 2008
    Michigan
    Hello,
    I'm new to the group and was looking for some help. I have an 05 GTP and I find that my factory sunroof leaks. I've had the car since new and no problems until recently. Any suggestions? Thanks
  2. #2 Re: New to group - leaking factory sunroof
    Becca Boo MizzBecca's Avatar
    Michigan
    Welcome =) sorry no suggestions. But figured I'd welcome you anyway.
    I drive a POS
  3. #3 Re: New to group - leaking factory sunroof
    New Brunswick
    sometimes the drain pipes that drain the water away between the roof panel and headliner get clogged...also it could be around your onstar antenna since these things are known to leak( I beleave if it is this you will have water leaking near the reading lamps...)
  4. #4 Re: New to group - leaking factory sunroof
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    welcome
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  5. #5 Re: New to group - leaking factory sunroof
    Nov 2008
    Michigan
    Water is coming in at the reading lamps. Headliner is also wet and starting to stain. I've looked and can't seem to find what I think would be the drain pipes. There are tubes sticking up but I can't imagine they would be used to drain water. Where would the drain pipes be located?
  6. #6 Re: New to group - leaking factory sunroof
    Nov 2008
    conn
    call mr chatman,1-866-932-4368, ext 38747,when my nose on my 01 started showing yellow thru the paint,he called a dealer for me and it was painted the next day,no charge..
  7. #7 Re: New to group - leaking factory sunroof
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by blown gt View Post
  8. #8 Re: New to group - leaking factory sunroof
    New Brunswick
    I beleave they run down near the rear pillers, I cant be certain thoguh but I can find out in my service manual tonight...I would also remove the map light assembly and spray water around the onstar antenna to see if that could also be leaking since I have heard of that happening alot and the onstar antenna is right above the reading lamps or almost there.
  9. #9 Re: New to group - leaking factory sunroof
    Nov 2008
    Michigan
    Thanks for all the suggestions. I suspect the OnStar since water is coming through reading lamps and surrounding headliner. Also, I noticed that it seems to be slightly loose and not sealed properly towards the sunroof side.
  1. Sunroof still leaks...FOUND PROBLEM FINALLY
    By 99prixgt in forum General Tech Discussion
    Last Post: 05-19-2011, 09:52 AM
  2. Sunroof
    By K1J1E2 in forum General Tech Discussion
    Last Post: 03-12-2009, 11:43 PM
  3. Help with sunroof!
    By kbwent in forum General Tech Discussion
    Last Post: 02-22-2009, 08:55 AM
  4. HELP! Sunroof
    By GTPluv in forum General Tech Discussion
    Last Post: 10-19-2008, 07:04 PM
  5. sunroof still leaking
    Last Post: 08-27-2008, 12:32 AM
