Thread: new fom denver i have 2 question maybe you can help
Results 1 to 5 of 5
  1. #1 new fom denver i have 2 question maybe you can help
    henderson co
    Hi im new to the forum i have a 99 gtp with zzp frt and rear ported mainfolds, ss intercooler,3.1 moduler pulley,3"down pipe with cat delete and 2.5 straight pipe to mufflers,and 1.9 rockers also zzp 1.0 pcm i lve in denverand race at bandimere elevation around 6000 ftbeen to the track one time with this set up and i cant get the car to hook at all even with nito drag radials my one good pass was a 14.1 at 98mph does anyone have any ideas or tricks to help with this problem?
    second question is i ordered a updated computer for my car from zzp ,when i installed it i got a p0753 shift selonoid code and trans was stuck in second gear,put the old computer back in problem solved,i called zzp back left 4 messages not that they have my cash there customer service skill are not so good. has any one else had this type of trouble with zzperformance?
    thanks
  2. #2 Re: new fom denver i have 2 question maybe you can help
    TDCRacing
    Guest
    Quote Originally Posted by strykergxp View Post
    thanks
    Yes. File a charge back with your card company that you ordered everything with.
    The reason you can't hook up is because you have the nitto's. The best thing you can do is buy a set of non DOT slicks.
    Also be sure your posting in the correct section.
    Welcome to the community.
  3. #3 Re: new fom denver i have 2 question maybe you can help
    St. Louis Mo.
    thanks
    I love Bandimere Raceway! It is awesome at night! Another thing you may want to consider if you are not getting traction, is to lower the air pressure in your front tires. It won't be as efficent as slicks, but it will give you better traction than what you are getting now. I know when I have raced at Gateway over in IL, I use to drop my PSI down 20-15psi range, it seems like you are almost running flat, but with that lower pressure, you are putting more rubber to the ground for contact. Just remember to pump them back up before hitting the highway
    ZZP has had some issues of late no doubt, but just keep sending them emails and phone calls, hopefully they will get your issue resolved.
    James Shafer
    St. Louis MO
  4. #4 Re: new fom denver i have 2 question maybe you can help
    TDCRacing
    Guest
    Quote Originally Posted by GeddyLee View Post
    Good point. This one slipped my mind compleatly.
  5. #5 Re: new fom denver i have 2 question maybe you can help
    henderson co
    Thanks for the info,the class i run at bandimere requires dot tires.I think i might try putting my street tires back on and lowering the tire pressure.
    Has anyone ever heard about backing up and them lightly jumping on it to engage both frt tires? that seems to be my biggest problem is that it only spins one time when i launch.
    I finally got a call back today from zzp after 3 more calls, i think they are going to take care of the problem.
    thansks again for the info i race this friday,we"ll seen if i can do any better.Hopefully the track conditions will also be better.
  1. tuner in denver?
    By riceburner in forum West
    Last Post: 12-21-2009, 11:46 PM
  2. Colorado Springs/Denver area
    By DesQ27 in forum Introductions/Noob Questions
    Last Post: 08-11-2009, 08:36 PM
  3. Noob from Denver
    By jzh898 in forum Introductions/Noob Questions
    Last Post: 05-15-2009, 03:37 PM
  4. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  5. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
