Hi all! Been poking around silently for way too long, so it's time to start interacting. No problems to report or ask about, just a guy from Central New York State who probably put way too much money into his 3800 Series III NA Grand Prix. Might not beat a Hellcat in a race, but she sure is a fun and peppy ride now and holds her own in class! Looking forward to sharing some good chat about our rides. Cheers!
2005 Pontiac Grand Prix: ZZP 1.9 Rocker Arms with 90# Valve Springs and LS Style Retainers, HV3 Intake Insert, Rollmaster Double Timing Chain, ZZP Hardened Crank Shaft, Throttle Body Spacer, 180* Thermostat, ZZP Milled Oil Pump Cover, ZZP Front and Rear Power Logs with ZZP Crossover Pipe, ZZP Downpipe with High Flow Cat, ZZP 1.0 PCM Tune, ZZP Cold Air Intake, ZZP Oversized Radiator, ZZP High Voltage Coil Packs with Autolite XP104 Iridium Spark Plugs and ZZP 10.5mm Spark Plug Wires, ZZP Silicone Hose Kit.
