Thread: Low oil pressure
Results 1 to 2 of 2
  1. #1 Low oil pressure
    Jul 2022
    Tuksa
    I have a 2004 Grand Prix 3.8 v6 that low oil pressure light is on, there is plenty of oil in the engine, no knocking or rattling sounds coming from the engine. Any sugs?
  2. #2 Re: Low oil pressure
    St. Louis
    Check the oil pressure sending unit, it's screwed into the back of the adapter where the oil filter mounts to the engine block. These are known to leak oil into the connector and even fail bad enough to drain an engine if unchecked. If you go to replace it be careful as it is an NPT thread and doesn't take a lot of torque to snug it up. Too much and you'll crack the filter adpater.
  1. Hi pressure low pressure fuel connectors , i lost the springs that go inside. help
    By Hardonyomom in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2014, 09:31 PM
  2. help installing oil pressure gauge and fuel pressure gauge
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-06-2012, 07:23 AM
  3. vac pressure?
    By backinblackgtp in forum Audio, Security & Visual Electronics
    Last Post: 03-26-2010, 09:44 AM
  4. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  5. Low Oil Pressure?!?!
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-04-2008, 03:07 PM
