#1
damn Headlights and Hello
Owner of an 04 GTP and just replaced the headlights. Now I have one down and in and th eother up and out. I see the up down screw on top but do not see anything for in and out. I have owned this car from May of 03 as it was the first one the dealer got. i love it but the headlight deal sucks..
Help please.
#2
Re: damn Headlights and Hello
Up and down is the only adjustment. If you feel you need to go in and out, either you need a new bulb or the enclosure is in wrong.
#3
What type of bulb did you use? LED or halogen? I ask because the LED bulbs require rotation to get a good beam out of them. You could try rotating the halogen bulb, but I doubt it will do anything. Also, check to see if one of the headlight tabs broke while tightening or possibly the piece of guide plastic isn’t in the slot (not sure if your year has it). 97-03 has the inner tab that slides into a slot on the core support, behind the grill a tiny bit.
#4
the left/right adjustment is towards the inboard side of the capsule and is down low.
"Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
