Thread: new to forum not to gm
Results 1 to 2 of 2
  1. #1 new to forum not to gm
    Oct 2019
    Washington
    my brother has a 200 something grand prix that doesn't run. i used to but only until it gets warm then it would die. so he added more gas , now it is full. but still won't start. he tried to spray starting fluid in and it tried to start but no go. his son tried to get in the car to work on it and the drivers side door wouldn't open and now the handle is broken and the parts to the window is in the bottom of the door. i am thinking either no spark or no gas or a bad crank sensor i am not sure i am used to fords and the principal is the same. i will take a spark tester a compression gauge and a fuel pressure checker and a rubber hammer to beat on the fuel tank to try to jar the pump loose. it hasn't run in 6 months and i need to pump the old gas out.
  2. #2 Re: new to forum not to gm
    St. Louis
    If you have someone listen under the tank or even in the trunk, when you turn the key to ON, not start, you should hear the fuel pump prime for a few sec. then shutoff. If not, check the fuses first, then maybe smack the tank and see if you can get it to spin up. If you're lucky you can pull back the carpet right behind the back seat in the trunk and see if there is a fuel pump access panel. Should be a few bolts and the cover comes off and there's the pump.
    Do your basic checks for spark and fuel and go from there.
  1. New to forum, PA, and GPs.
    By camaroholic in forum Introductions/Noob Questions
    Last Post: 09-21-2014, 10:17 AM
  2. New to Forum
    By 00RedfireGT in forum Introductions/Noob Questions
    Last Post: 07-09-2014, 03:44 PM
  3. New to the forum
    By alexrs2426 in forum Introductions/Noob Questions
    Last Post: 06-15-2014, 09:35 AM
  4. New to the forum
    By foytz14 in forum Introductions/Noob Questions
    Last Post: 09-21-2011, 08:45 AM
  5. Hello: I'm new to this Forum
    By obey in forum Introductions/Noob Questions
    Last Post: 04-08-2011, 11:41 AM
