Thread: 2008 Grand Prix losing power going up hill
Results 1 to 20 of 29
  1. #1 2008 Grand Prix losing power going up hill
    Nov 2013
    pittsfield ma. 01201
    My Grand Prix started losing power when going up hill just started today.Check engine light flashes when it happens then stops when car hits level ground no fault codes showing thanks for any help
  2. #2 Re: 2008 Grand Prix losing power going up hill
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    No codes ? Says what ? DIC? or actual scan tool ?
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  3. #3 Re: 2008 Grand Prix losing power going up hill
    Nov 2013
    scan tool
  4. #4 Re: 2008 Grand Prix losing power going up hill
    May 2016
    Rouge Island
    K, swierd. I thot 4 sure a flashing cel would set a code ?
  5. #5 Re: 2008 Grand Prix losing power going up hill
    SE Level Member Moozery's Avatar
    Apr 2016
    Ontario
    Does it also flash during WOT?
    Pre-Production 2004 GP GTP Comp G / 91,000mi / TransGo Shift Kit, Spectre Open Cone, 180 Tstat, AL605's, ZZP 3" catted DP, ZZP front PLog, Intense PCM, GMPP Sway Bar
    Access Old "How-To" Links
  6. #6 Re: 2008 Grand Prix losing power going up hill
    clogged cat or it needs a tune up super bad.
    scan the car running after it flashes, it might show a pending code. pending codes can clear if you shut the car off.
  7. #7 Re: 2008 Grand Prix losing power going up hill
    May 2016
    Rouge Island
    Ahhh..
  8. #8 Re: 2008 Grand Prix losing power going up hill
    Nov 2013
    Scotty just started getting a po300 code new plugs and wires last year
  9. #9 Re: 2008 Grand Prix losing power going up hill
    Nov 2013
    Did not try this
  10. #10 Re: 2008 Grand Prix losing power going up hill
    Nov 2013
    Showing a p0300 code after a rescan
  11. #11 Re: 2008 Grand Prix losing power going up hill
    how many miles it got? ever been tuned up ? 300 is the multiple misfire code.
  12. #12 Re: 2008 Grand Prix losing power going up hill
    Quote Originally Posted by daviddawg View Post
    missed this post, miles? cat might be clogged.
  13. #13 Re: 2008 Grand Prix losing power going up hill
    Nov 2013
    Got 120000 on car new plugs and wires at 100000 also had to change ignition control module at same time and a bad coil . Just found out when in park and rev up engine noticed it wont rev past 3500 rpms
  14. #14 Re: 2008 Grand Prix losing power going up hill
    Nov 2013
    No flash but will only rev up to3500rpm
  15. #15 Re: 2008 Grand Prix losing power going up hill
    SWPA
    That's how it is supposed to be. That is a safety feature.
    Also there is no flash because there is no load. If you want to put load on the engine put it in drive and with your left foot on the brake hit the gas with your right.
  16. #16 Re: 2008 Grand Prix losing power going up hill
    GT Level Member Gregorius's Avatar
    Davenport, IA
    Here's a funny thought.
    What if was a clogged fuel filter, and the fuel pump had enough on level ground, but once it had to pump "uphill" too......lol would also explain the P300's.
    I'm still drinking coffee, ignore me.
    Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
    WarStryker13's Google drive
    ... our lady of blessed exceleration, don't fail me now ...
  17. #17 Re: 2008 Grand Prix losing power going up hill
    not, heres the deal, flashing cel means one of two things almost always. cat, or needs a tune up real bad.
    pull the o2 sensor to make a exhaust leak pre cat, it should run better if the cats bad, sound like crap tho.
  18. #18 Re: 2008 Grand Prix losing power going up hill
    May 2016
    Burns City, Indiana
    A flashing CEL means its breaking NOW. Attaching a scan tool and reading whats going on. Looking at long term and short term fuel, o2 readings, misfire counters if available.
    One old time test for fouled cat is warm engine then rev it up and hold it at around 2000-3000 rpm and I like sitting a plastic jug about for or so away from exhaust pipe. Generally if converter is plugged the exhaust is forced through smaller area and super heats converter and exhaust and can be felt at tail pipe.
    Proper diagnosis starts with reading PIDS. Fuel psi , air in, LT/ST, map, IAC if equipped, o2 ranging, misfire counters per cylinders.
  19. #19 Re: 2008 Grand Prix losing power going up hill
    Nov 2013
    Thanks for everyones input.Up date on problem found an vacuum hose leaking replaced hose car ran better but still starts losing power when you get up to 40 miles an hr.
  20. #20 Re: 2008 Grand Prix losing power going up hill
    cause clogged cat.
  1. 2005 Grand Prix Losing power
    By kirt70camaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-30-2016, 12:35 PM
  2. 2008 Grand Prix: Where in the heck is the Power window fuse!!
    By mcdavidhome in forum General Grand Prix Discussion
    Last Post: 08-26-2013, 04:07 PM
