What would I need to do to disable daytime running lights?
The only reason I went and got this is because I knew right where it was. Just saw it today looking for something else.
http://www.grandprixforums.net/threa...-04-grand-prix
Thanks, hmm says it may work on older models, wonder if anyone has tried it on on an 02.
EDIT: Oh nevermind, read the thread a bit more and one of the comments said for 97-03 cars to just "pull out the plug that goes into the heatsink behind driverside dash.".
I disabled mine by pulling a fuse
Check your owners manual. Should be listed.
Depends on the year. Some '01+ cars you can't just pull the fuse.
When I pull the fuse, the DRL diode buzzes. If I unplug the DRL diode and remove the fuse, the DRL's don't work, plus the "auto" on" function stops working also. So, I just have the DRL diode unplugged. If you don't want the "auto on" to work, you need to unplug the DRL control module. I have the headlight wire removed from the plug of the module, so just the park lights "auto on".
Here are some visuals:
http://chrisb.users.superford.org/Gr...tml#MAY27-2015
