Thread: how to replace lifters and pushrods 3.8 series 2
Results 1 to 2 of 2
  1. #1 how to replace lifters and pushrods 3.8 series 2
    Dec 2014
    TN
    need info or diagram on how to replace fix im not mechanice but have idea on how to use some tools
    any help great thanks
  2. #2 Re: how to replace lifters and pushrods 3.8 series 2
    Mar 2017
    Internet
    Asking something like this on such a durable engine that rarely see's failures with these parts, might get us asking why you are looking to do so because we might be able to help diagnose it with you. In case it's not lifters or rods.
    The procedure will be basically.
    Remove fuel rails and electrical connectors to most things on top of the engine.
    Remove upper intake/sc
    Remove lower intake
    Remove front and rear valve covers (if w body this will include the coil pack bracket)
    At this point you will have access to the rockers/rods and lifters.
    Rocker bolts are considered by GM to be Torque To Yield and are expected to be replaced when you do the job.
  1. Replies: 34
    Last Post: 03-08-2016, 09:57 PM
  2. Do you need to upgrad pushrods with XP cam and Ls7 lifters and 130# springs?
    By timboku in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2015, 10:21 AM
  3. Pushrods and lifters?
    By Loftus1995 in forum Turbo
    Last Post: 03-14-2015, 01:08 PM
  4. Replies: 28
    Last Post: 03-11-2015, 10:44 PM
  5. VS Cam..Pushrods/Lifters?
    By Blake71091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2014, 02:15 AM
