Thread: Was once a regular, now I'm back
Results 1 to 6 of 6
  1. #1 Was once a regular, now I'm back
    SE Level Member curtcamaro's Avatar
    Pella, Iowa, United States
    Used to be on this site all the time. glad to see when i came back that not much has changed .
    I in the other hand went out searching for a gtp....and ended up buying a GXP...how does that happen>? Anyways. I'm so used to looking to ZZP for performance mod ideas, is there a similar site that is geared towards the LS4? Or am i best off just doing exhaust and intake and call it a day? PS already have K&N cool air intake from previous owner.
    97 GT $500
    Put a motor in and repainted.....now spent $800 more.
    Not bad for a $1300 car.
  2. #2 Re: Was once a regular, now I'm back
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    There are cams, intake mani's, tb's, etc for it but the trans isnt going to like it very much.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  3. #3 Re: Was once a regular, now I'm back
    You'll have to open that wallet alot more if you wish to mod the LS4 that's for sure.
    Any cam swap will require a DoD/AFM delete kit, new cam, cam gear, lifters etc etc. The DoD feature is somewhat problem prone to begin with, most tune the feature out to help prevent it from failing. And if you do exhaust work, you'll want it gone or turned off because it sounds terrible in V4 mode.
    Headers are pricey for a nice set.
    LS1Tech has a LS4 section that is worth viewing and reading.
  4. #4 Re: Was once a regular, now I'm back
    Apr 2014
    South Haven, MI
    I never got the idea behind DoD. I get that it shuts off 4 cylinders for fuel savings but wouldnt it work the engine harder because the rotating mass is still there.
  5. #5 Re: Was once a regular, now I'm back
    It doesnt take a ton of effort to keep things spinning, they picked the best cylinders to shut down so that the force given on the cylinders still firing is plenty to keep things moving. Pretty lame answer but it's true.
  6. #6 Re: Was once a regular, now I'm back
    Kemmerer, Wyoming
    Furches performance and over kill both have some gxp support
  1. Regular or Synthetic Oil?
    By CyxRyan in forum General Grand Prix Discussion
    Last Post: 06-07-2013, 12:26 AM
  2. Top swap and regular gas.
    By rob11715 in forum General Grand Prix Discussion
    Last Post: 11-04-2012, 09:43 PM
  3. hp tuners... regular or pro?
    By jakewet28 in forum PCM Tuning
    Last Post: 02-20-2011, 08:02 PM
  4. How bad is regular gas for your gtp?
    By GMCARS4LIFE in forum General Tech Discussion
    Last Post: 08-16-2010, 02:44 PM
