Thread: White Smoke?
Results 1 to 8 of 8
  1. #1 White Smoke?
    SE Level Member 1FastGP's Avatar
    May 2015
    Indian Trail, NC
    So for about the past month every time I start my car (02 GT) it will smoke a hazy white out the exhaust for 5 to 10 minutes. It doesn't matter if it's hot or cold or if it's been sitting for a week or 10 minutes it will smoke. I will post a video later. Any ideas?
    Sent from my SM-G900V using Tapatalk
  2. #2 Re: White Smoke?
    Jan 2014
    AR
    If its not just exhaust system condensation that has become more visible since weather is turning colder....
    it could be an early warning sign of upper intake manifold trouble. Especially if it has the original equipment and gaskets in place. I'd check the oil and coolant first for any strangeness or low level. Since coolant makes white smoke (steam), oil makes blue, and fuel makes black. Catalytic converters can mess with smoke signals though. Pressure testing the cooling system and inspecting spark plugs could provide further clues, as could a report of any work thats been done to it lately. Oh yeah and a vid later.
  3. #3 Re: White Smoke?
    May 2015
    Indian Trail, NC
    I put an HV3 in like a week before it started so I'm kind of leaning toward my problem being around there. And to go along with that is there supposed to be oil pooled up in the upper intake
  4. #4 Re: White Smoke?
    Yes, oil pools in the corners from the PCV.
  5. #5 Re: White Smoke?
    how cold is it there now? a cold pipe will condensate as its warmed up. mine just started this crap this last week. once the pipes are warmed up it stops.
  6. #6 Re: White Smoke?
    May 2015
    Indian Trail, NC
    It's 70 in NC today but it did when it was close to 80 or down in the 20's. Maybe it is the pipes but my grandma's car with the same exhaust doesn't do it so who knows.
  7. #7 Re: White Smoke?
    thats pretty warm out for the cold pipe scenario.
    after it sits for a bit pull the plugs to see if they are wet with coolant.
  8. #8 Re: White Smoke?
    GXP Level Member
    Mar 2015
    Tomball
    Unless the humidity is really high, we have that down here even on a warm engine of the car has been shut off for about 20-30 minutes.
    Jeff
  1. white smoke?
    By bluedude22 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-19-2013, 12:51 PM
  2. white smoke :'(
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2011, 10:50 PM
  3. white smoke.
    By gtpinsc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-17-2011, 12:08 PM
  4. White smoke
    By dhaller in forum General Tech Discussion
    Last Post: 04-14-2010, 08:13 PM
  5. White smoke
    Last Post: 04-10-2010, 06:29 PM
