Thread: Tire width questions
Results 1 to 3 of 3
  1. #1 Tire width questions
    Nov 2015
    I'm new to this site and I have a question. I have two tires that are exactly the same with the exception of the width. One tire is 234/35r19 and the other is 245/35r19. The other two tires are both 235/35r19's. The first two tires I mentioned are brand new Falken Azenis. Am I safe toe drive those up front? Will it be bad for my transmission, and will it be safe to drive on? I can roll them I. The rear is its bad for the tranny but the tread is better and if I can I'd like them in front. Any info is appreciated. I'm not even sure if this is where I post a question lol.
  2. #2 Re: Tire width questions
    hangover park IL
    on the front you want two of the same size tires with even wear from side to side, anything other than that is cycling your differential even when your driving straight and that leads to alot of wear and tear, not to mention pulling/alignment issues.
    the rear it doesnt mater other than maybe giving you a slight dogleg/uneven tracking
    also keep in mind a change in the tire rollout might also end up giving you false abs triggers on stops when turning
    ~James~ Psychotic Gearhead
  3. #3 Re: Tire width questions
    SWPA
    235/35/19s are 25.4" tall
    245/35/19s are 25.8" tall
    Both of those are about an inch to an inch plus inches too short. The size you want is 245/40/19 which come in at the stock height of 26.7" tall.
    As mentioned having 2 different size tires on front is hard on your transmission. It can also cause ABS to disable due to different circumference whether the different one is on front or back.
  1. Couple Tire Questions
    By M7x350z in forum Tires & Wheels
    Last Post: 04-30-2014, 12:06 AM
  2. 2004 pontiac Grand Prix Wheel/Tire width
    By RFlippy in forum General Grand Prix Discussion
    Last Post: 10-27-2013, 08:57 PM
  3. wheel / tire questions.
    By TJWA07GXP in forum Introductions/Noob Questions
    Last Post: 01-18-2012, 01:41 PM
  4. Tire questions
    By GPGT2004 in forum Tires & Wheels
    Last Post: 07-29-2011, 09:43 PM
  5. Factory gxp wheel / tire questions
    By funkenmiester in forum Tires & Wheels
    Last Post: 05-19-2010, 09:50 PM
