Okay guys, so my uncles heat is cold as ice. He's driving a 02 Le Sabre. So I go take a look at it and the only visible problems I saw are that his coolant elbows are leaking a little bit, that's no problem easy peezy. So we have the car on for about 15 minutes with the heat blasting on full and I go and feel the heater hoses and they're are stone cold, but the radiator hoses are hot. I take a look at his coolant and it's at the right level but it's as murky as pond water. So I ask what's he been putting in the coolant and he whips out dollar store green coolant. So fellas, is this a case of a clogged heater core or heater hoses? Is a coolant flush the most logical solution, along with replacing coolant elbows and tstat?
