Thread: How To: Upgrade Your Fuel Filter!
Page 1 of 3 123 LastLast
Results 1 to 20 of 59
  1. #1 How To: Upgrade Your Fuel Filter!
    Enfield, CT
    First off, there are NO pictures regarding how to do this upgrade unfortunately but this info comes from a trusted friend that's been working in the auto industry for 33 years. He did this on an '02 Chevy Impala and his '05 Bonneville. I was gonna do this on my '97 GP but the line never seized or broke so I didn't bother.
    Secondly, this is considered an upgrade because some people end up breaking and/or twisting the line trying to get the fuel filter off and need to repair it. Sometimes the nut and line rots or seizes. It's also an upgrade due to the fact that this will make filter changes easier then ever.
    Last but not least, Credit and Thanks goes to TurboMike321 for supplying photos and a simple walk through.
    Parts and tools can be found at NAPA or wherever you prefer.
    What you'll need:
    1. Dorman 3/8 In. Quick Connector, Straight w/ 18 In. of 3/8 In. Nylon Tube PART# 800-058
    You don't need to use the entire 18". Just cut to fit.
    2. Compression Fitting
    Fuel Line Connector PART# 730-5642
    3. Fuel Filter of your choice
    NAPA PART# 3193 (Wix makes NAPA Filters)
    AC Delco PART# GF624K
    Wix PART# 33193
    Fram PART# G7333
    4. NAPA Tubing Cutter PART# 2107
  2. #2 Re: How To: Upgrade Your Fuel Filter!
    Enfield, CT
    Reserved
  3. #3 Re: How To: Upgrade Your Fuel Filter!
    Oct 2013
    United States
    Did this to mine.. Makes the filter change so much easier.. Hope you don't mind me posting some how to pics
    FYI: in order to choose your preferred brand of fuel filter.. just look up a 95 chevy caprice 5.7 to get yours
  4. #4 Re: How To: Upgrade Your Fuel Filter!
    Oct 2013
    United States
    parts required *(line cutter not pictured)*
    prepping the new line for install.. pay attention to the fitting's orientation
    where i chose to cut my line.. seems like a good place
    all connected and finished
    now fuel filter change takes about 5 minutes or less..
  5. #5 Re: How To: Upgrade Your Fuel Filter!
    Damn that looks like a good idea. And a lot of rust.
  6. #6 Re: How To: Upgrade Your Fuel Filter!
    Buffalo
    Lmao thread-jacked the poor dudes how-to
  7. #7 Re: How To: Upgrade Your Fuel Filter!
    Oct 2013
    United States
    Ehh.. i wouldn't call it a thread jack, per se, But he did say he didn't have any pics of the job.. i just supplied the pics from when I did mine..
  8. #8 Re: How To: Upgrade Your Fuel Filter!
    Buffalo
    No worries... I know what you mean.
    I would be interested in trying this as well. Matter of fact I almost DID do this because I think the nut on my line is finally done for.
  9. #9 Re: How To: Upgrade Your Fuel Filter!
    Oct 2013
    United States
    It's worth it.. gm should have just made them all this way..
  10. #10 Re: How To: Upgrade Your Fuel Filter!
    Quote Originally Posted by turbomike321 View Post
    I was just thinking the same thing.
  11. #11 Re: How To: Upgrade Your Fuel Filter!
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    How do you put the brass ribbed connector peice into the hard line?
  12. #12 Re: How To: Upgrade Your Fuel Filter!
    Apr 2015
    Nevermind, turbomike, what part number is that compression fitting? Or what size?
  13. #13 Re: How To: Upgrade Your Fuel Filter!
    Enfield, CT
    Thanks for the pics. I would've uploaded some if I ever got around to doing this job.
    Quote Originally Posted by SallyBabe03 View Post
    Yea definitely not a thread jack. Just had to do something for a how to because it's tiring when people keep making a thousand posts on how to fix the fuel filter line.
    Might do a suspension thread and consolidate all the info. Too many what springs, which struts, will these wheels fit, etc....
    Sent from my LG G3
  14. #14 Re: How To: Upgrade Your Fuel Filter!
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    Quote Originally Posted by HighOctaneRacing View Post
    Might do a suspension thread and consolidate all the info. Too many what's springs, which struts, will these wheels fit, etc....Sent from my LG G3
    Do it
  15. #15 Re: How To: Upgrade Your Fuel Filter!
    Oct 2013
    United States
    Quote Originally Posted by SubwayGirl View Post
    I got mine from Napa.. Part # 730-5642
    They come in a pack of two.
    They are 3/8 inch.
    They are called steel to nylon compression unions.
    Assemble as shown in pic above
  16. #16 Re: How To: Upgrade Your Fuel Filter!
    Apr 2015
    Does the little clear rubber piece on the end of the flexible line come in the package or does it come on the hose? And the little brass piece with a hex on one side and then it tapers inwards, which way does that go in?
  17. #17 Re: How To: Upgrade Your Fuel Filter!
    Oct 2013
    United States
    The clear piece comes with the unions.. The way I have everything in the pic, is exactly how it goes when installing on the car.
    Step one
    Slip the nut over nylon line, then put the clear sleeve over the end of the nylon line, assemble union to nut at nylon line.. NotIce that the nylon end has an inner stem on the union
    Step two
    Slip the nut over the steel line on car, then the metal sleeve, then attach union to steel line on car
  18. #18 Re: How To: Upgrade Your Fuel Filter!
    Apr 2015
    Everything in the cart looks good right?
    The compression fitting says it has different attachments for 1/4", 5/16", and 3/8".
  19. #19 Re: How To: Upgrade Your Fuel Filter!
    Oct 2013
    United States
    Yes.. that's correct.. the unions you selected comes with 3 sizes.. ie. Multi pack
  20. #20 Re: How To: Upgrade Your Fuel Filter!
    Apr 2015
    Thank you Mike! I've got it now .
  1. WTB: fuel line from injectors to fuel filter for 99GTP coupe
    By Swole in forum Wanted To Buy - Parts
    Last Post: 08-25-2014, 02:36 PM
  2. sluggish / misses / dies / did tune up w fuel injection / did fuel filter / car runs
    By dlc723e in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-30-2012, 08:25 PM
  3. Changed Tranny Fluid/Filter, Fuel Filter Tonight
    By nickbuol in forum General Tech Discussion
    Last Post: 10-15-2010, 06:04 PM
  4. upgrade filter
    By Mad Monkey in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-23-2009, 12:41 AM
