Thread: gxp questions 5.3l
Results 1 to 4 of 4
  1. #1 gxp questions 5.3l
    May 2015
    canada
    Hey guys I know this has probably been posted before but I'd like to know some tips and tricks for changing the drive belt on a 5.3l
    I know gm/ kent-moore has the special belt wrench, but I know there must be some tricks, I've heard of people prying on the tensioner spring or
    loosening tensioner assembly, any other tips?
    am also going to do the thermostat, seems like it would be easiest to access from underneath as the exhaust manifold is in the way.
    any thoughts on that?
    thanks for the help.
  2. #2 Re: gxp questions 5.3l
    Donating Users timboku's Avatar
    Montgomery, IL
    Quick and Dirty LS4 Belt removal
    http://www.grandprixforums.net/showthread.php?t=77867
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  3. #3 Re: gxp questions 5.3l
    May 2015
    canada
    sweet, appreciate the reply, I wonder about this prybar bar method, if your just pry against the top of the tensioner spring and against the frame
  4. #4 Re: gxp questions 5.3l
    Montgomery, IL
    The hose clamp is easy and safer and only 2 bucks. I did it to replace my water pump worked great.
  1. HID Questions
    By 2dee11 in forum Visual/Body Modifications
    Last Post: 07-27-2013, 06:15 PM
  2. Window Tint Questions and Rear Speaker Questions
    By Wisconnie in forum General Grand Prix Discussion
    Last Post: 06-22-2013, 07:17 PM
  3. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  4. My WBS IC Questions
    By footballplaya3k in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2011, 01:53 PM
  5. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
