Thread: Making a bigger cubby hole in center console [*]
Results 1 to 12 of 12
  1. #1 Making a bigger cubby hole in center console [*]
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    This HOW TO on Modification of the Center Console has been added to the How To section and can be found HERE.
  2. #2 Re: Making a bigger cubby hole in center console
    I live here. UR LOSN's Avatar
    Rockford, IL
    you could fit, 2....3....dead bodies in there tops....
    not bad, I often wondered about making the GT's bigger. just use it for penny's I cant fit with the rest of the coins...
    what are the ones in the dash for?
  3. #3 Re: Making a bigger cubby hole in center console
    Port Hope Ont,Canada
    Heads up display goes into the one
    on the drivers right and on the left ?
    1998 GTP, U-Bend Delete,Hi-Flow Cat,No Res,SLP Headers,BRISK Plugs ,180 T-Stat, 3.4 pully
    2007 GM Show and shine August 10http://www.youtube.com/v/aRh91q1jRio&rel=1
    OQCGP Clubhttp://www.youtube.com/v/j_YHmgU9ehs&rel=1
  4. #4 Re: Making a bigger cubby hole in center console
    SW Chicago Suburbs
    as far as i know, the one that came on the left was just that, a cubby.
    the one on the right is supposed to be for the hud switch... but if you see in another thread of mine, i'm moving the hud switch over to the left one, cuz it seems to me that havng the cubby on the right would be more beneficial.
  5. #5 Re: Making a bigger cubby hole in center console
    yeah that might have been a option
    to either have it on the right or left since they both are the same..
  6. #6 Re: Making a bigger cubby hole in center console
    SW Chicago Suburbs
    Quote Originally Posted by J_Ferguson View Post
    all the factory mounted hud switches are on the right... the harness isnt long enough to get to the left. that's why i'm putting together an extension harness for mine.
  7. #7 Re: Making a bigger cubby hole in center console [*]
    Nov 2008
    Heaven, compared to HERE
    actually I have seen at least one with the hud on the left cant remember if it was a 97 or 98 but it Definitely had the hud on the left. I remember because I was like ...where did the...Oh there it is...WEIRD. I even ask about it...IIRC the guy said he had seen a few like that...and related it may have been a dealer installed add on that the customer wanted vs ordered from factory. Just my $0.02...take it or leave it.
  8. #8 Re: Making a bigger cubby hole in center console [*]
    Jan 2009
    NYC/SW Florida
    I actually installed my GPS into my cubby hole, spaces on the right and the left are for my Cigarettes and Sidekick LX respectively. Helps to know which parkways and shortcuts connect to where when your running from the cops in an unfamiliar part of town... (Fort Myers, AKA "Fort Misery", Florida)
    P.S.- Originally from NYC..
  9. #9 Re: Making a bigger cubby hole in center console [*]
    May 2008
    McHenry IL
    lmao nice if i had a gps i would put er ther 2 man lol
  10. #10 Re: Making a bigger cubby hole in center console [*]
    SE Level Member comongoose's Avatar
    Jan 2009
    Gainesville, Fl
    pictures please
    -1999 GTP...Work in Progress! L26 bottom end, K&N HAI, ZZP MPS 3.5" pulley, headers, custom intake, 180 therm., 1.9 rockers
    -1996 Acura TL
    -1995 Trans Am...SOM beast...RIP.
  11. #11 Re: Making a bigger cubby hole in center console [*]
    SE Level Member 0LmtdGP3800's Avatar
    Feb 2009
    Iowa Falls, Iowa
    can i get pictures of the gps install sounds sweet!
  12. #12 Re: Making a bigger cubby hole in center console [*]
    Donating Users ROTTMAN's Avatar
    Feb 2009
    canada
  1. Making Jerky for the first time
    By Andrew_99GTP in forum Off Topic Discussion
    Last Post: 04-02-2012, 10:56 AM
  2. making a cheap cold air intake ?
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2010, 04:10 PM
  3. Supercharger Fill Hole Bolt Stripped
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 06:20 AM
