Thread: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
Page 6 of 6 FirstFirst ... 456
Results 101 to 112 of 112
  1. #101 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    Quote Originally Posted by 2003 SSEi View Post
    or tuned
    Yep. Still running stock tune with Aeroforce scan gauge to monitor KR.
  2. #102 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    Will an mini-AFC let me swap to 42.5 injectors without a tune?
  3. #103 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Yes, That should be easily doable.
    04 GTP -HAI, 1.9 rockers.
  4. #104 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    May 2012
    Where winter never ends
    People used to tune with the miniAFCs all the time lol
    2000 Regal - Winter Beater
  5. #105 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Aug 2013
    Sandy, UT
    the 42lbers are almost exactly 30% bigger, so set the dip switches in the afc to scale your maf by 30% up or down, whichever way that works.
  6. #106 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    SE Level Member oldsman105's Avatar
    Queens, New York
    Wouldn't the car be running rough and rich because the PCM cannot calculate fuel correctly. Instead of using a AFC get spare pcm and have someone make the changes you need for the 42.5 injectors and LQ4 Maf.
    2002 Pontiac Bonneville SSEi
    Gen V with 3.6 pulley , 1.9 Rockers, L76 Springs, N* TB, 40lb injectors, Power log, 3" Down-pipe
  7. #107 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    Quote Originally Posted by oldsman105 View Post
    You are changing the AF the exact same amount you are changing the in injector size. It should be seamless.
  8. #108 Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    Mini update.
    I'm running 3.0 pulley with hybrid phenolic intercooler, gen 5, ported heads, front p-log, ported stock rear manifold and 1.9 yella Terra. (Stock exhaust and DP). Pretty sure I can jump to a 2.8 but it's winter.
  9. #109 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    I think I left out a fitting. You need 2 of these 1" barbed to 3/4" barbed. Anybody know where you can just get one not 10?
    Eldon James C16-12BN Automotive Black Nylon Reduction Coupler, 1" Hose Barb to 3/4" Hose Barb
    https://www.amazon.com/Eldon-James-C...CDDY9T5D3583A0
  10. #110 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Kemmerer, Wyoming
    I wonder if there would be a noticeable increase in coolant flow if you swapped some of the coolant hoses from 3/4" to 1.25" instead of reducing the hoses down directly at the radiator inlet/outlet. obviously not all the hoses could be swapped because the intercooler core uses the 3/4" and the intercooler pump uses the 3/4".
  11. #111 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Nov 2012
    pistolvania
    Quote Originally Posted by sseilmnop View Post
    did you ever figure out were to get these
  12. #112 Re: Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
    Mercer, Pa
    I got fittings in bulk.
    https://www.ebay.com/itm/112443006584
  1. VS Cam vs S2/Phenolic Intercooler
    By Nchristopherson in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2013, 08:10 AM
  2. Ported gen5 and phenolic intercooler
    By 2007gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2011, 05:51 PM
  3. New Intercooler Design Phenolic Core
    By minichopper6hp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2011, 12:52 AM
  4. Phenolic Intercooler Spacer
    Last Post: 03-22-2009, 12:03 PM
