Thread: ZZP Fuel Logs Install [*]
Results 1 to 6 of 6
  1. #1 ZZP Fuel Logs Install [*]
    GTX Level Member webracin's Avatar
    Arkansas
    This HOW TO on Installing the ZZP Fuel Logs has been added to the How To section and can be found HERE.
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  2. #2 Re: ZZP Fuel Logs Install [*]
    SE Level Member scooz14's Avatar
    West Bloomfield MI
    if using the new generation
    step 1, git rid of POS FPR. get prj to make you up a block
    12.591@108.00 1.95 60'
    329.9hp 400.1tq
    http://www.mccgp.com/member_details.php?mid=95
  3. #3 Re: ZZP Fuel Logs Install [*]
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Quote Originally Posted by scooz14 View Post
    If you have done this could you give me some info on getting rid of the FPR? I have the old style buy I have a friend that has the newer style with the adjustable FPR and he doesn't care for it and thinks it could be causing him some trouble.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  4. #4 Re: ZZP Fuel Logs Install [*]
    West Bloomfield MI
    contact prj about it. i know he has done it before
    im sure it is causing him problems. it is absolute garbage
    329.9hp 400.1tq
  5. #5 Re: ZZP Fuel Logs Install [*]
    Arkansas
    I have never had a problem with mine, however the PRJ does look nice....
    PRJ Regulator Block
    webracin
    2001 Grand Prix GTP
  6. #6 Re: ZZP Fuel Logs Install [*]
    New Salem, ND
    Ok, thanks for the info
  1. rear window regulator/motor install write up
    By ExpyGator in forum General Tech Discussion
    Last Post: 11-17-2009, 12:52 PM
  2. did I do an install on your gp today?
    By s1795so2 in forum Midwest
    Last Post: 01-06-2008, 06:56 PM
  3. did I do an install on one of you guys cars today?
    By s1795so2 in forum Off Topic Discussion
    Last Post: 01-06-2008, 06:53 PM
  4. Aftermarket headunit install on BOSE system??
    By FoSHO99 in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2008, 03:51 AM
