Thread: 97-03 Cluster Gauge LED Install
Page 4 of 4 FirstFirst ... 234
Results 61 to 77 of 77
  1. #61 Re: 97-03 Cluster Gauge LED Install
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by Bronco Boy View Post
    I got some of the DD HP3 bulbs months ago, and finally got around to installing them.....
    Very happy with the outcome, except now my "dimly lit" signal indicators are brighter.....
    And a picture with the signal on showing how "dim" the indicators are.....
    Did you ever get this figured out? I run Diode Dynamics LEDs on the front and rear exterior lights and the LED flasher. Mine were lit up on the actual HUD. The LED flasher did not fix the issue. I actually had to install a load resistor on each corner light which fixed that as well as my cruise control as I have diode dynamics LED's in the third brake light location.
    The only thing that I have right now that is funky is that the LED below the PRND321 location blinks when I have the turn signal activated during the day. Once I turn the lights on at night that issue goes away. So there is feedback coming from somewhere.
  2. #62 Re: 97-03 Cluster Gauge LED Install
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by The Guz View Post
    I never did figure this one out.
    Yikes. So you did get the cruise control issue.
    I feel lucky not to have had this issue. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #63 Re: 97-03 Cluster Gauge LED Install
    Dec 2008
    Lawndale, CA
    Yeah I did have the cruise control issue. Put the load resistors on even though I already had the LED flasher and everything worked like normal.
    I wonder if load resistors would solve the issue you have.
  4. #64 Re: 97-03 Cluster Gauge LED Install
    Jul 2010
    Coquitlam,BC,Canada
    Maybe, but I don't do load resistors; defeats the main purpose of LED's. I suspect that if I put a resistor on each light to drain the extra power I might be ok, like this... https://www.youtube.com/watch?v=JbP-pt4aczs
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #65 Re: 97-03 Cluster Gauge LED Install
    Donating Users Paul J McCain's Avatar
    St. Louis, MO
    Load resistors don't defeat the main purpose at all. The main purpose is to produce more light output and have a modern blink rate.
    Nick C.
    Click For All Pontiac Lighting
    Your Experts in Pontiac Lighting
    (314) 205-3033
  6. #66 Re: 97-03 Cluster Gauge LED Install
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Paul J McCain View Post
    I use LED's to reduce load, so using load resistors defeats this purpose.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #67 Re: 97-03 Cluster Gauge LED Install
    Dec 2008
    Lawndale, CA
    Made updates to the first post. Since photobucket screwed things up, I re-hosted the images.
  8. Likes Supercharged99 liked this post
  9. #68 Re: 97-03 Cluster Gauge LED Install
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    Cool that you did that. Photobucket really messed up a lot of threads on here...
  10. #69 Re: 97-03 Cluster Gauge LED Install
    Dec 2008
    Lawndale, CA
    Thought I would post a little feedback.
    I have had Diode Dynamic LED's installed on the entire exterior along with the LED tails. The flasher module worked to remove the hyper flashing but the turn signal arrows would appear on the HUD as well as the cruise control feature not working with the Diode Dynamic LED's in the 3rd brake light. The solution was adding load resistors to the 3157 front corners. This was working fine for the past year and all of the sudden the left turn signal appeared back on the HUD and would light up a couple of the LED's on the driver side Muth mirrors.
    Took a closer look on the driver side corner thinking the load resistor lost it's connection. Connection was intact. Swapped a incandescent bulb and that fixed the issue. I recalled I had placed LED's into the turn signal indicators behind the cluster. I pulled the dash apart and replaced the turn signal LED's with incandescent bulbs and put the LED back into the driver side corner. This fixed the issue. I had the same issue on my 2002 Camaro with everything not functioning properly with LED's in the cluster gauge turn signals. Essentially not enough loading on the circuit.
    Something to keep in mind for those wanting to run LED's everywhere.
  11. #70 Re: 97-03 Cluster Gauge LED Install
    Jul 2010
    Coquitlam,BC,Canada
    Yup. I did this about a year ago. I found the HP3 led's in the dash cluster signals were a tad bright too. So, when they starting flickering after less than a year of use, I put the old incandescents back in.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  12. #71 Re: 97-03 Cluster Gauge LED Install
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Wouldn't load resistors equivalent to the resistance value of each bulb in series with the led fix this issue? Maybe I'm not understanding the fault... new to leds lol
  13. #72 Re: 97-03 Cluster Gauge LED Install
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by wstefan20 View Post
    You would think so. In this case, they did work, but then stopped working. Maybe some other factor in play? This is what I hate about LED's. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  14. #73 Re: 97-03 Cluster Gauge LED Install
    Dec 2008
    Lawndale, CA
    Well yes and no lol. The load resistors were what I thought a permanent fix. Now it did fix the 3rd brake light and cruise control feature which probably works fine now with the incandescent bulbs back in the turn signal locations on the cluster lol. There were times when I thought the connection was loose and the driver side turn signal indicator would display as being "ON" in the HUD display as if the bulb was out. It would also light up the bottom two LED's on the driver side Muth mirror. I never thought much about it because a little wiggle of the wires with the load resistor and the issue went away. This last time it did not go away with a wiggle of the wires and thus I took it apart this weekend to inspect if something was loose.
    Recently I replaced the cluster LED's on my 2002 Camaro. I did not order enough so I was short two for the turn signal indicators. This car has no load resistors but rather the appropriate LED flashers. So when I received the two LED's I was short I swapped them them into the turn signal indicators. When I tested them out with the turn signal lever and flasher, only one side would blink. The other side would not make a noise through the flasher or blink internally and externally. As soon as I put the incandescent bulbs back into the cluster the issue was gone and everything worked together.
    This is what caused me to swap put the bulbs in the cluster of the Grand Prix. It seems to be working fine.
    GM wiring at it's finest and the quirky LED behavior.
  15. #74 Re: 97-03 Cluster Gauge LED Install
    GT Level Member 97gtp01gt99gt's Avatar
    Sep 2018
    Saint Louis
    How did u get the 04 needles to work properly
  16. #75 Re: 97-03 Cluster Gauge LED Install
    Dec 2019
    Omaha, NE
    Quote Originally Posted by 97gtp01gt99gt View Post
    I'm not sure what you mean by "work properly", but it's a really easy swap. You'll need to trim the stems to the same length as the stock needle stems and make sure you don't push them down too far so they don't catch, but other than that, there's not much to it. Just mark where the stock needles are at idle, carefully pop them off (I used a fork and gently rocked it back and forth to pop them off), and put the new needles on pointing to where you marked them.
    '99 Grand Prix GT - The winter beater - top swap coming this summer
    '00 Honda S2000 - Turbonetics T3/T4, E85 tune, too many other mods to list
    '14 BMW 528i - The "nice weather" daily driver
  17. #76 Re: 97-03 Cluster Gauge LED Install
    Dec 2008
    Lawndale, CA
    Semi related to the cluster. The digital DIC can be swapped to LEDs as well.
    I tried a couple options.
    The diode dynamic 74SMD1 has good color but not good output in the 360 degree range. It leaves hot spots. In the other areas it works ok due to the light being separated.
    The better option is the super bright led 74x-HP3-CAR. It provides even light dispersal in the main part of the DIC.
    One thing to keep in mind is that by going the LED route, it the other areas of the DIC will be more noticeable(ie: metric areas, indicators for the doors, etc).
    To complete the job, it requires 5 bulbs. Three in the DIC and two for the low trac and trac off.
    Red is color that is needed. A size 74 bulb does fit.
    74 LED Bulb - 3 SMD LED - Miniature Wedge Base | Super Bright LEDs
  18. Thanks NotEnoughGPs thanked for this post
    Likes NotEnoughGPs, ThatOldCarSmell liked this post
  19. #77 Re: 97-03 Cluster Gauge LED Install
    Dec 2008
    Lawndale, CA
    After a few years one of the LEDs went out on the dash cluster.
    Purchased a brand new set of HP3’s from diode dynamics.
    Here is cool white
    Warm White. This is close to the incandescent bulbs.
  1. Gauge cluster fix???
    By 92GPcoupe in forum General Tech Discussion
    Last Post: 02-28-2013, 06:02 PM
  2. Red Gauge Cluster
    By ShadowSwept in forum General Grand Prix Discussion
    Last Post: 09-09-2012, 04:04 PM
  3. le gauge cluster fuel gauge dnt work
    By cliffdawg in forum Visual/Body Modifications
    Last Post: 11-21-2011, 08:50 PM
  4. Swapping a 3 gauge cluster for a 6 gauge cluster
    By knoppsicle in forum General Tech Discussion
    Last Post: 10-16-2011, 09:49 PM
  5. Gauge Cluster
    By boy1dur in forum General Tech Discussion
    Last Post: 09-02-2009, 06:52 PM
