Thread: Exhaust Manifold Removal
Results 1 to 7 of 7
  1. #1 Exhaust Manifold Removal
    Nov 2013
    Michigan
    Hello. I'm removing my stock manifolds from my 2001 Grand Prix GTP, and will be replacing them with SLP headers. I was wondering what the best way is to remove them. Also, I heard that if you remove the engine mounts, the whole engine will turn forward, which makes it easier to get to the back. Is this true, or does anyone have any tips for this? Thank you!
  2. #2 Re: Exhaust Manifold Removal
  3. #3 Re: Exhaust Manifold Removal
    Dec 2012
    troll land
    Penetrating oil, lots of it. Rear mite b easier to lower rear sub and drop it out
  4. #4 Re: Exhaust Manifold Removal
    Nov 2013
    Michigan
    Thank you dsmuts! I guess I can't forum too well. I have another question. I bought used headers, and they're a bit dirty. It looks like parts of the outside got sort of burned off. What do you guys usually use to clean them up and make them look nice? Do you trust the Rust-Oleum exhaust paint on headers or will they peel?
  5. #5 Re: Exhaust Manifold Removal
    I'd just run them. They'll get ugly again eventually.
  6. #6 Re: Exhaust Manifold Removal
    Like Smuts said... Their going to discolor anyways.. Just run them. I rather leave them alone then go through the hassle of pairing them to only find that the paint has burned off.
    04 Comp G.
  7. #7 Re: Exhaust Manifold Removal
    Nov 2013
    Michigan
  1. Cracked exhaust manifold
    By PALMCASTER GT1 in forum General Tech Discussion
    Last Post: 02-10-2012, 10:22 PM
  2. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  3. Exhaust manifold removal
    By trenaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-29-2011, 10:56 AM
  4. upper manifold/ throttle body removal help!!
    By joshsGT in forum General Tech Discussion
    Last Post: 08-13-2010, 11:30 AM
  5. exhaust manifold ?
    By 04GTPCOMPG in forum General Tech Discussion
    Last Post: 11-09-2009, 03:20 PM
